Old 09-04-2009   #1
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Shifter question
Just put in the symbrosky shifter kit and noticed a little play on the top bolt right below the shifter nob threads. The bolt is tight but it leaves a little side to side play in the shifter. Is their something I can get to replace the bushings on there or something I can do to tighten up the shifter or is the shifter supposed to be like that?
Old 09-04-2009   #2
Re: Shifter question
You could buy brand new bushings from Mitsu, but there is always going to be a little play. Did you install the Symbrowski replacement tube as well that comes with the metal base bushings?
Old 09-05-2009   #3
bertrenolds5
Yep, did the tube also. The shifter is alot stiffer now and I am really glad I got the symbrosky kit! The play doesn't bother me to much but it would make the shifter feel even more solid without it. Gonna make a call to satan about the bushings, shouldn't be to much. Hopefully replacing them will actually tighten it up a little.
