Go Back   MitsuStyle > Hosted Support Forums > DB Performance
PayBan Fest 2010 is going on right now! Get in on the action and payban your friends! 100% Proceeds go to dyno day prizes!
Old 09-09-2009   #1
ecoli
DB Performance
ecoli's Avatar
Send a message via AIM to ecoli
Got Fuel?
Just got a set of these in with Mitsubishi adapters on them for DSMs, Evo 8 and Evo 9. 2200cc at a 43.5 base fuel pressure and they are capable of being run at extremely high fuel pressures, unlike most fuel injectors.
The 1000cc version of these injectors tune, idle, and respond like a factory stock injector. We have tuned a bunch of S2000s, Acura RSX's, and turbo B-Series cars on the 1000s and they usually run amazing. The 2200s should hopefully kill the 1600s out there in idle quality and drivability. The main problem with the 1600s is not that they are too big, it's that they are just a poor injector and do not have linear enough flow, a pulse width of 1.5ms can actually give less fuel than 1.25ms. That can cause problems and force you to have to run the car richer at idle and part throttle with the 1600s to get any drivability.
I am trying these tomorrow on an Evo 9 with an AEM EMS on it. Even with an aftermarket peak & hold injector driver box, the AEM EMS can't handle the 1600s very well, so this should be a good test.
ecoli is offline   Reply With Quote
Old 09-09-2009   #2
Re: Got Fuel?
are these the Injector Dynamics units that T1 sells?
Research is the difference between speculation and investment.
Old 09-09-2009   #3
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Got Fuel?
Sick!
Old 09-09-2009   #4
i like pink
Drives: T2T for HSA
Re: Got Fuel?
they look really nice how will would they work on link
1995 Evolution III
1998 awd spyder
1989 turbo mirage hatch
1993 mirage sedan 4g63t swapped
2001 mirage sedan
1951 mercury m-1 truck
There is only room for 1 bad speller and it is me
Old 09-09-2009   #5
ecoli
DB Performance
ecoli's Avatar
Re: Got Fuel?
Yep. They are a step up from the big Siemens Deka injectors as far as tunability goes.
Old 09-09-2009   #6
ecoli
DB Performance
ecoli's Avatar
Re: Got Fuel?
They should work great, since the OEM Mitsu ECU injector drivers can handle the 1600s and 1650s better than most ECUs. The 1600s/1650 aren't perfect with the factory ECU/DSMLink, but at least the car usually drive decent.
They are very expensive, but they avoid having to goto a 2 fuel rail setup, different intake manifold, and 8 injectors on a lot of cars(1000s or smaller primaries for idle/drivability with 1600 secondaries coming on under boost), or if you actually need more than 1600 of flow.
Old 09-09-2009   #7
Re: Got Fuel?
Very expensive is right! Sheesh!
Old 09-09-2009   #8
Drives: 04 Lezbaru, 04 Gay-lant & 94 Talon in progress :)
Re: Got Fuel?
How much?
Counting the days till project 1g is alive again.
Old 09-09-2009   #9
i like pink
Drives: T2T for HSA
Re: Got Fuel?
around 240.00 each
might have to save to get a set for the spyder when I start working on it some day. but whats a few more years since it has been apart for almost 8 years now
1995 Evolution III
1998 awd spyder
2001 mirage sedan
Old 09-09-2009   #10
Re: Got Fuel?
around 240.00 each
Old 09-10-2009   #11
Drives: a Titleist
Re: Got Fuel?
That's a bargain when you figure in how much it takes to have two rails, eight injectors, and the corresponding fuel lines to do it. Plus you could run these with Link, doing eight injectors with Link takes some measures I wouldn't be comfortable with. At least before the new version came out.
Old 09-10-2009   #12
ecoli
DB Performance
ecoli's Avatar
Re: Got Fuel?
Well, they seem to work very well. No problems controlling the A/Fs at idle or cruise, runs/smooth fine at 1.0 lambda cruising part throttle. They respond like a normal injector, tune like a PTE/FIC 1200-1250.
Old 09-10-2009   #13
Re: Got Fuel?
Wow! What local evo9 needs these? I wanna see the dyno chart
Old 09-10-2009   #14
Re: Got Fuel?
^^ I'm guessing maybe that white one that sat in their shop forever.
Old 09-10-2009   #15
viridionplague
Re: Got Fuel?
better off buying these vs buying 2 sets of injectors at the same price, then avoid buying the extra rail, extra lines, and extra tuning required to run so much stuff
Old 09-10-2009   #16
ecoli
DB Performance
ecoli's Avatar
Re: Got Fuel?
Just some E85 street car Evo 9 MR.
Old 09-10-2009   #17
ecoli
DB Performance
ecoli's Avatar
Re: Got Fuel?
That was an Evo 8 from a couple years ago.
Old 09-10-2009   #18
Re: Got Fuel?
that makes RIDICULOUS power
Old 09-10-2009   #19
El Hombre Polla
Penguin Shot Champion!
Drives: a piece of shit car.
Re: Got Fuel?
That's a lot of money. I wish there was a proven 1600 size injector that would tune like a smaller injector and take care of the "drivability" issues that most 1600's tend to cause.
B-man
91 Tsi AWD: 2.0 & 03 "Voy": 4.2 I6 & 06 Bayliner 195: V8
TC FlexFuel Mafia
JKODIS Coatings CEO!!
Idle vid - 541hp Vid - 10.93@137 Vid
Old 09-10-2009   #20
Re: Got Fuel?
stfu and post the graphs punk!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
