Old 09-10-2009   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
ported 1g head -$350
Have a ported head that needs a valve job. The timing belt skipped a few teeth on the dyno and bent at least 1 valve. The head has the QPR stage 3 port job and also has crower springs and retainers. The intake side of the head was also ported and I have a phenolic (sp) spacer to go with it also to help the flow. The head didn't have many miles of run time on it (maybe a few hundred miles max) since it was rebuilt, ported and the springs and retainiers were installed so it is fairly clean. Just needs a few new valves and a little cleaning from sitting in my garage. The head might also have some longer exhaust manifold studs installed in case someone was going to install a bigger turbo and needed a spacer plate. I am not sure though. It will either have the longer studs or none. It doesn't have the old ones in it. The head does not come with cams.
Looking to get $350 for it. I spent $400 on the porting and $250 on the springs and retainers alone.
PM if interested.
7/25/09
Old 09-10-2009   #2
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Re: ported 1g head -$350
Pending sale.
7/25/09
