Old 10-05-2009   #1
4seasons69
4seasons69's Avatar
evo3 head vs. 1g head
I'm just curious if anyone knows if there is anydifference between the two what the pros and cons are between the two?? thanks for any info you have
Old 10-05-2009   #2
Re: evo head vs. 1g head
Evo heads resemble 2g heads, if anything; but they are far from identical.
Evo 8 and 9 heads are different as well.
This question is rather vague. Specifically what year evo head are you referring to?
Old 10-05-2009   #3
4seasons69
4seasons69's Avatar
oh shoot I'm a little tired I meant to put evo3 head in the title
Old 10-05-2009   #4
4seasons69
4seasons69's Avatar
I purposely made the question a little vague cause I picked up a 6bolt with 10k on it and it's supposed to have an evo3 head on and I'm just trying to figure out what I can about them
Old 10-05-2009   #5
Well, i know evo3 heads are their own deal; They aren't exactly a 1g head or a 2g head.
The intake manifold flange is different on the evo 3 heads, so it should have a matching intake manifold with it. A 1g or 2g intake will not work.
Old 10-05-2009   #6
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Intake manifold flange different?
An Evo 3 head is a 2g head but with different cams from my understanding. Smaller ports like the rest of the evo 4-8 heads (except turned around)
Other then that they are identical. The Evo 3 came with a different Intake then a 2g. What does the intake manifold look like?
If you have a 1g intake, it is a 1g head (with big ports) or they ported the heck out of the Evo 3 head
Old 10-05-2009   #7
Re: evo3 head vs. 1g head
Mark will know, he's the resident evo3 expert. SuperBleeder is right though, the E3 head is similar to a 2G head, but not identical.
Old 10-05-2009   #8
I may have misinterpreted what i had heard about the intake flange.
It may be that the intake will bolt up, but the ports still wont match up.
Old 10-05-2009   #9
4seasons69
4seasons69's Avatar
alright well it has a 1g intake mani on it. do you know how to tell if it's actually an evo3 head?
Old 10-05-2009   #10
ok
evo 3 head
2g size intake ports
the intake ports are a straight shot to the valves
uses 2g gasket
they have bigger cams stock over a dsm
the springs are alittle heaver
the valves are lighter and sodium filled (If it is the evo III head and not a evo I-II head)
uses a 94 style halo cas
the evo I-III heads are pretty much the same you need a casting number to find out what it came off of.
Old 10-05-2009   #11
4seasons69
4seasons69's Avatar
the cas is definitely different than the one on my 90. I'll take off the intake manifold and look at the intake ports and see what they look like. is there anything else that could verify that it's an evo3 head like any markings on the cams or anything? thanks for the replies
Old 10-05-2009   #12
4seasons69
4seasons69's Avatar
well the intake ports on the head are definitely the same as the 1g intake manifold. it also doesn't look like it's been machined to port match them either. is it safe to say this is actually just a 1g head??
Old 10-05-2009   #13
Andrew7dg
Andrew7dg's Avatar
ok
evo 3 head
uses 2g gasket
Is the port angle different on a Evo 3 vs a 2g?
I guess I thought the Evo and the 2g heads were pretty much the same except for the stuff bolted on to it.
Old 10-06-2009   #14
Forced Fed
Drives: FS-T
Yes, the port angle is different from what I've researched online.
Forced Fed is offline   Reply With Quote
Old 10-06-2009   #15
CBRE
Im switching both of my cars to 2g heads, hope im doing the right thing, Kiggly does very well with the 2g head. For a street car(wich my cars are) I think it would be MUCH more drivable.
CBRE is offline   Reply With Quote
