Old 10-11-2009   #1
evo8: tephra v7 is out!
This is ONE universal rom for ALL 2003-2005 evos! And YES there was no v6
Tephra has come a LONG way with his tweaked roms. I've been running the final test version of this rom since June and I absolutely love it. If you're getting your evo re-tuned and/or you're using ecu-controlled boost, I highly recommend upgrading. The bigger tuning maps in this rom give the tuner more refined control of the a/f and timing the car runs under various conditions.
For ecu-controlled boost users, WGDC is held at 100% until load surpasses load of 200. This made a VAST improvement on the responsiveness of my car, and the snappy response you get from a MBC is (or is nearly) achieved with this, because the wastegate is held shut until you approach your preset target (just like a MBC). Also BWGDC is now GEAR BASED so overboosting in higher gears is a thing of the past. With the max-upwards-tps table zero'd out and mrfred's directboost mod done, this has been the most solid EBC setup I've ever used. Every gear, same boost no massive corrections needed so it always feels nice, smooth, and powerful.
AFR/Knock safety thresholds. KnockCEL is tied into the ecu-controlled boost, and if AFRs are out of spec or the high knock threshold is hit, the ecu can pull boost back.
SPEED DENSITY enabled roms are available! Check post #2 of the thread. I don't think anyone locally is running this way yet, but enough people globally have been testing it that IMHO its safe to try!
http://forums.evolutionm.net/ecuflas...hramod-v7.html
Originally Posted by tephra View Post
TephraMod V7
yeah finally
First of all I would like to thank everyone who has contributed to the development of this, I reckon some of the new features are awesome
Secondly if you would like to donate just PAYPAL whatever you can/want to donations@globalshare.net
FEATURES
Flashing CEL on Knock
- slow flash for low knock
- fast flash for high knock
- low and high knock thresholds customisable
- minimum load threshold customisable
- can get it to drop boost if above the High knock threshold
Valet Mode
- customisable RPM limit
- autovalet on fresh ignition (ie if you leave the car and come back it will auto valet, as opposed to returning to the previous state you left the car in)
- NOT able to co-exist with TPS based map switching
- CEL will fast flash on ignition if valet is enabled
Alternate Maps
- 3 methods of switching maps - ADC0F (ie Jack_of_Trades harness OR meth failsafe), Intercooler Auto Switch (ie hold down for prescribed time), TPS switching (ie hold TPS like Valet mode)
- all 3 methods WONT switch TO AltMap when car is above load threshold
- ADC0F switching WILL switch BACK to Normal Maps if voltage drops below threshold - hence meth failsafe
BIG MAP
- changed ECU to use new BIGGER MAPS for both Fuel and Timing
- same axis's for both sets of maps
- altmaps and launch maps included
- LOW OCTANGE FUEL AND TIMING INCLUDED as well
- does NOT affect other timing maps, ie EGR or ColdStart
2byte to 1byte load factor
- simple divide routine to convert 2byte load into a 1byte field and then Evoscan will convert back to 2byte.
- MATCH you LoadFactor in ECUFLASH to the SAME as your Eval in evoscan
- MaxLoad is loadfactor * 255, ie a loadfactor of 1.2 will allow a Max Loggable Load of 306, 1.3 = 331... etc (choose an appropriate loadfactor based on your existing max load)
No Lift to Shift (NLTS)
- basically set's a revlimit of whatever your CURRENT RPM is (ie when you shifted) MINUS the RPM Drop you specify in EcuFlash
- Various thresholds ie TPS/Speed/Load so it wont activate by accident
- If you do have problem's its probably your top clutch switch.
- Always do the garage test (ie set speed to 0, tps to 20, load to 0 and then practice the engangement point whilst idling)
AFR Safety
- REQUIRES WB02 wired upto the rear02
- various thresholds and timers
- will Flash CEL AND/OR Drop boost
Launch Maps
- Allows you to customise your "Launch" igition and fuel maps
- various thresholds so it only activates on Launch
- Should override altmap mode as well
FULL Gear based boost control
- removed existing BDEL and BWGDC tables
- added new 3d tables with gear on the X axis
- allows you to have different boost levels AND wastegate duty cycles for each gear
TPS compensation for WGDC
- Basic multiplication table for WGDC
MAF IAT compensation for WGDC
- Allows you to add or remove WGDC based on intake air temp
100% WGDEC under a certain load
- Keeps BCS from openning wastegate under a certain load (to aid in spool up)
INSTALLATION
This time all you have todo is make sure you have a recent copy of EcuFlash (1.41+ is good) and you just COPY the entire .xml file into your EcuFlash XML directory. No more patching xml files.
BIG WARNING
Whilst I have tried to test everything as much as possible it is up to YOU to test each feature before driving your car around! If you notice any WEIRDNESS (including EcuFlash showing funny values for things) please post up so we can help you!
ROMS
96530706 TESTED by Phenem,
941700XX, 969600XX, 964200XX??? - See Phemen's first reply down below!!
88590015, 90550001, 88580014, 88570008, 96260009 + MORE COMING SOON!!!
I can try and help answer any questions or implementation questions, post up!
