Old 11-30-2009   #1
talonite
talonite's Avatar
Drives: 1997 Eagle Talon TSI
balance shaft eliminator kit
hey i was wondering if anybody knew of a write up somewhere on how to do the balance shaft eliminator kit. Or just any advice on doing it, im tackling this project this week and kinda need some guidance on it.
talonite is offline   Reply With Quote
Old 11-30-2009   #2
Re: balance shaft eliminator kit
If you have the proper parts, you pull off the front cover, pull off the two balance shafts. The one driven by the oil pump either gets a turned down shaft or a stubby shaft. With the stubby shaft you need to remove the old bearings (use the old balance shaft to pound them out) and reinstall new bearings but use them to block off the oil passages. Check VFAQs.com or DSMTuners.com for a more detailed writeup.
Old 11-30-2009   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
http://vfaq.com/mods/balance-shafts.html
-1990 Mitsubishi Cyborg 4WD-
Old 11-30-2009   #4
talonite
talonite's Avatar
thanks guys.
