Old 01-31-2010   #1
2zzgtte
The Russian Stub
2zzgtte's Avatar
Drives: 2001 Celica, 2005 Evo
Am I burning lean or REALLY lean?
My car seems to go threw spark plaus every 4,000 miles. I thought I was burning really rich because my gas mileage sucks, and it smells like it. Something isnt right though.
Last 2 times I have changed my spark plags, the seem to come out whiteish. I changed my plugs last time because my car seems to misfire when they start going bad. The last time I changed my plugs the misfiring went away. Yesterday it went away. It is back today...
I didnt think I was burning lean the first time I changed my plugs. I just thought it was the Amsoil P.I. I put in there. Well my plugs tell a different story.
Here is the one I just pulled out. I only pulled 1 out because I didnt have time to pull the rest. Going to the Wolves game. Let me know what you guys think.
(Seems like best lighting is in my bathroom...)
Here is an old one with about 3 - 4000 miles on it (right) vs. a new one with maybe 100 - 150 miles on it... (left)
2zzgtte is offline   Reply With Quote
Old 01-31-2010   #2
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Am I burning lean or REALLY lean?
Get your car tuned. You shouldnt be having problems going through plugs since your setup is so basic.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 01-31-2010   #3
Those look good to me. *shrug* Mine look the same and have probably 10,000+ on them.
Old 01-31-2010   #4
2zzgtte
The Russian Stub
2zzgtte's Avatar
Do you remember when we were coming back from Michigan and you said my car sounds like its burning rich? the exhaust still smells like that but my plugs dont seem to show evidence of it burning rich.
Then I wonder why they keep misfiring. Around 3 - 4000 miles they start to misfire. When I replace them, the misifring goes away. This time it didnt i guess...
Old 01-31-2010   #5
Sounds like it's rich? Please tell me how you can hear such a thing.
Are your plugs gapped correctly?
Old 01-31-2010   #6
mlomker
*Resting In Peace*
mlomker's Avatar
I guess if it were possible to tune using plugs then we wouldn't need afr gauges.
Old 01-31-2010   #7
mike55112
mike55112's Avatar
Drives: 04 evo
I remember I could hear a little misfire and it smelled rich. Slap in your cams and have shane tune it
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-01-2010   #8
No, but plugs are a good indication of engine health and overall performance.
Old 02-01-2010   #9
Those plugs look just fine to me.
Old 02-01-2010   #10
Probably needs a tune! They look a little sooty to me, I bet its too rich!
Invest in a wideband.
Old 02-01-2010   #11
wants to be sideways...
123abc's Avatar
Drives: Loud cars
What are you gapping your plugs to? Are you on a stock setup/injectors or whats the story?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-01-2010   #12
311evo
311evo's Avatar
I'm wondering about the gap too.
Otherwise tune. Do you have an intake on it?
Edit: Boost leak test done.. ever?
Old 02-01-2010   #13
2zzgtte
The Russian Stub
2zzgtte's Avatar
Oops, sorry. It should have "smelled" rich.
My gap is .025 on BPR7ES.
Haha, "slap" them in... I'm not mechaniclly inclined so nothing is "slapping" it in... Plugs is the easiest thing for me to do but that still takes me a while lol
3" tbe with testpipe
obx intake tube with k&n typhoon carbon airfilter and heatshield
ebay licp
turboxs h34 bov
mbc at 23psi
walbro 255
dynoflash ecu reflash
No boost test ever done. Maybe I should try one? Maybe I should try compression test while I'm at it too.
Old 02-01-2010   #14
If you are that concerned about your car when the plugs look fine then you really should do a boost leak test and have Shane look at the tune. You aren't going to get a magical answer by making forum posts on the internet.
Old 02-01-2010   #15
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
He's just trying to build his post numbers. Give him some slack
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 02-01-2010   #16
2zzgtte
The Russian Stub
2zzgtte's Avatar
Lol, Sorry guys. I thought they looked lean to me. Just thought I'd ask. I could care less about post numbers
Old 02-01-2010   #17
GsXtUrBo98
GsXtUrBo98's Avatar
Lol, it was a joke.. I was giving some shit.. just bored at work like matt d I guess.
98 GSX (built)
03 BBY EVO dd
Old 02-01-2010   #18
2zzgtte
The Russian Stub
2zzgtte's Avatar
I am in the same boat as you guys... Trying to get my Google Talk to go through my Proxy and it just wont work. Since we have came to a conclusion about my spark plugs, maybe someone can give me advice on that?? lol
Old 02-01-2010   #19
Your plugs don't look fouled out or anything, and they aren't covered in oil residue either.
Copper plugs don't last forever either though. You might have a weak coil(stock Evo coils suck) or bad plug wire, if it will only fire smoothly with perfectly new plugs. Or your ignition timing in the tune could be too far off.
A lot of people confuse the smell of a car idling/running lean with that of a rich car. Lean smells very noxious. Really rich and gas will be coming out the exhaust pipe, but it will smell like raw gas and your plugs will usually be dripping wet.
Old 02-01-2010   #20
Good call shane, stock coil boots and plugwires go bad quicker than most people think; if the car is missing and the plugs are not gunked up, def replace both (or do the spoolinup COP woot!). I have a good set of stock coils w/ good boots/wires if you want to borrow them as a test.
