Old 02-03-2010   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Faulty TPS
Hey all. I'm wondering if I have a faulty Throttle Positioning Sensor or another issue. It seems that everytime the car is fully warmed up, after I put it into neutral before a stop and the car wants to die. It doesn't even stay on idle.
For example; the car is warmed up, come to a stop sign, throw it into neutral and the car will immediatlely lose rev and die and the only reason it doesn't die is if I give it some gas, than it will keep idle (kinda used to doing this now and not letting the car die by itself). The reason why I'm suspecting the TPS is because I've replaced the ISC already, triple checked my vacuum lines (no cracks), no boost leaks. The CEL also comes up when I'm in 'cruise control' and then when I drive, the CEL disappears when I let go of the gas pedal (car is still in gear and moving at highway speed). So, could this be a faulty/dirty TPS?
ლ(ಠ益ಠლ)
Old 02-03-2010   #2
Re: Faulty TPS
I have this problem too if I let the RPMs drop from too high, so now I let it rev down to about 1800 while coasting and it catches at 1500 pretty easily.
But I didn't have this problem until I got a big turbo and intake pipe, and super light flywheel, apparently the DSMlink v3 MAF clamp helps fix the issue.
You should be able to log TPS volts, should be .63 at closed and between 4.5 and 5 WOT if I remember correctly.
Old 02-03-2010   #3
awd-drifter
'2of9'
Re: Faulty TPS
i don't have dsmlink or anything to check the tps volts. does oreily or any other shops have the tools to do this?
ლ(ಠ益ಠლ)
Old 02-03-2010   #4
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
Re: Faulty TPS
got a voltameter?
96GST16g is offline   Reply With Quote
Old 02-03-2010   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Faulty TPS
Check vfaq.com for info on how to check it.
-1990 Mitsubishi Cyborg 4WD-
Old 02-03-2010   #6
lucasoil4u
Drives: talon tsi evo 3 25psi
Re: Faulty TPS
yeah its not that hard just use a voltmeter and make sure that it doesnt have a spike or anything crazy. should be a nice smooth ramp up..
Mitsubishi.... Special Cars for Special People.
lucasoil4u is offline   Reply With Quote
Old 02-04-2010   #7
Re: Faulty TPS
Do you have an AFC? That will show TPS voltage.
Old 02-04-2010   #8
awd-drifter
'2of9'
Re: Faulty TPS
I have an s-afc. I will definately check it out.
ლ(ಠ益ಠლ)
Old 02-05-2010   #9
awd-drifter
'2of9'
Re: Faulty TPS
well, according to the s-afc, it says .510-.505 on idle. I haven't tried to make the car die because I just don't like the fact that it dies while I drive. Also, when I'm parked (after a warm up/short drive) I let the car idle and it drops revs to 500-600 than it finds idle again and than idles perfectly fine afterwards.
ლ(ಠ益ಠლ)
Old 02-05-2010   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: Faulty TPS
Your AFC should show throttle in % also. See if it's reading the right %. Just turn the key to the ON position and watch the throttle in percentage and go slow from 0% to 100% and make sure it's nice and smooth.
Old 02-05-2010   #11
Re: Faulty TPS
You TPS voltage with the throttle closed should be .61v-.63v. You can't use the throttle % on the SAFC to tell you if the throttle is set right, it is a learned range. Your volts could be 1.5v at idle and 3.5v at full throttle(which isn't close to right for a DSM) and it would learn that to be 0%-100%, but you could use it to make sure there aren't any dead spots or flaky readings as you slowly move the pedal from closed to full open.
Old 02-05-2010   #12
awd-drifter
'2of9'
Re: Faulty TPS
yeah, the throttle % is at 100%(closed) when at idle. Volts still showing .510-.505 for the throttle sensor. Seems like those numbers are lower than usual.
ლ(ಠ益ಠლ)
Old 02-05-2010   #13
Re: Faulty TPS
Adjust the TPS position then so it reads .63 at idle.
