Old 02-12-2010   #1
b00sted_spyder
FP turbo manifold guys, chim in please.
So I just received my manifold today. What kind of turbo bolts do you guys use? I know 2 factory ones can be used but what about the other 2 bolts closer to the radiator?
Old 02-13-2010   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: FP turbo manifold guys, chim in please.
If you can't get a bolt in, you can probably thread a stud in and use it that way.
7/25/09
Old 02-13-2010   #3
Chim55117
Drives: 2007 BMW 335i Coupe
I'm not really sure on what bolts you need, but when I saw the title I thought I would "chim" in since my screen name is chim55117.
Chim55117 is offline   Reply With Quote
Old 02-13-2010   #4
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I should payban you for this post.
Old 02-13-2010   #5
I got the bolts directly from FP, they work awesome. I think they use OEM Mitsu bolts for Evo o2 housing.
Old 02-13-2010   #6
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
FFWD has a kit with ARP's that fit.
Here's the link.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 02-13-2010   #7
Yeah, FP has a direct fit bolt kit. Basically the front two are noticeably shorter IIRC.
Old 02-13-2010   #8
spinz4
spinz4's Avatar
Send a message via AIM to spinz4
I used some that came from the o2 housing.
spinz4 is offline   Reply With Quote
Old 02-13-2010   #9
Here's the link.
I use the ARP's from FFWD, and really like them. I also remember reading the 02 housing bolts work, but haven't read about them in a very long time. Go ARP's that way whenever a part out goes through your mind they sell like hot cakes
Old 02-27-2010   #10
Manifold was designed to use OEM O2 housing bolts x2 and OEM turbo bolts x2.
