Old 02-17-2010   #1
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
T-case bracing?
Anyone know of a place that sells a brace for the transfer case? I know it's big for the 3000gt/stealth crowd, but I haven't seen one for dsm's. I found this pic, and was wondering if it's just homemade or what?
I want, and have been thinking about doing one for my car, since the t-case is aluminum, and I'd rather save it as best as I can. Ideas?
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 02-17-2010   #2
Re: T-case bracing?
Do you have a spare you can bring by? If there is enough interest we can come up with one. Any further info on why people would want this and if it actually helps?
1998 Spyder AWD
567hp
490tq
Old 02-17-2010   #3
Swifty1638
Swifty1638's Avatar
Re: T-case bracing?
I know especially for the 3kgt guys it helps the casing from flexing, and keeps the gears in check. Enough driveline shock would actually put enough torsion on the gears to "spread" them apart, cracking the case, and blowing the tcase up..someone correct me if I'm wrong. The bracing i've seen/installed on those cars looks like that of a mini roll cage, lol. I was just concerned because I'm afraid mine will do the same. I wish I had a spare, but I don't.
Black 1GB Mafia #1
I wanna go fast.
Old 02-17-2010   #4
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: T-case bracing?
Don't you have to actually race your car to be afraid of things breaking?
'04 Honda Ricer: stock
Old 02-17-2010   #5
Swifty1638
Swifty1638's Avatar
Re: T-case bracing?
Yea, shut up cher. Isn't there some fuel pump dilemma you are discussing on SF? This is a mitsu question..
Black 1GB Mafia #1
I wanna go fast.
Old 02-17-2010   #6
Re: T-case bracing?
I haven't heard of anyone breaking T-cases, but then again I don't drive a cool OMG HPowerz car.
Old 02-17-2010   #7
Swifty1638
Swifty1638's Avatar
Re: T-case bracing?
I have heard of it, and im more-so scared, that it will happen easier on mine, being all aluminum.
I do not drive a omghighhp car..
Black 1GB Mafia #1
I wanna go fast.
Old 02-17-2010   #8
Re: T-case bracing?
That looks home made to me, seems simple enough to make one.
Old 02-17-2010   #9
Re: T-case bracing?
I say skip it unless you start breaking them. I think the 3kGT ones are specific to that case, the DSM ones don't get shreaded as easily.
Old 02-17-2010   #10
Re: T-case bracing?
mini swifty bash/poke? ok:
Correct, it is in pieces! get that thing running!
Old 02-17-2010   #11
Re: T-case bracing?
Like who? Why don't you share since the seem to know all these people.
Old 02-17-2010   #12
Swifty1638
Swifty1638's Avatar
Re: T-case bracing?
Ok, calm down Aaron. Get off your high horse, and join the rest of us down here. Do a little research, you'll find it. Tcases blowing are a common occurance for anyone putting their drivetrain through hell. I just want to make that a less common occurance.
Black 1GB Mafia #1
I wanna go fast.
Old 02-17-2010   #13
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: T-case bracing?
It would make me feel better to have one
but which one would happen first?
destroy the internals of the transfer case, destroy transmission, or both before the mounts break?
Old 02-17-2010   #14
Re: T-case bracing?
Mitsu actually designed a fix for this. Do a search for GST
Old 02-17-2010   #15
Re: T-case bracing?
Why are you even worried about this happening? It's like you're building a track car that will never see the track. And no, like Aaron, I have not seen transfer cases exploding.
Old 02-17-2010   #16
Swifty1638
Swifty1638's Avatar
Re: T-case bracing?
Ok, keep your bantering for the swifty threads please. I asked a question. Answer it, or GTFO.
Black 1GB Mafia #1
I wanna go fast.
Old 02-17-2010   #17
Re: T-case bracing?
Fair enough! If anyone actually knows anything, please chime in. I think whether or not its worth it for 99.9% of dsms is firmly established.
Old 02-17-2010   #18
Re: T-case bracing?
I do not know of a place that makes them, have never seen them sold anywhere.
It looks homemade to me.
Ideas?
When you get slicks and track the car regularly then you may have a legitimate interest in reinforcing the transfer case. Until then I believe you should worry about other things that will matter more with your car.
Old 02-17-2010   #19
Re: T-case bracing?
I'm not on any high horse, just because I am making a valid point of
1. I haven't heard of anyone doing this, 10sec 600-700whp DSMs not destroying Tcases.
2. You trying to get your car ready for god knows what since you haven't even run a damn 11 or 12 in a DSM.
From what I understand about drivetrain breakages in general is that the flex in the drivetrain is what can put a lot of pressure on teh drivetrain even at moderate powers, considering a similar design is used in the evo and 3S its safe to say that the 3S chassis/drivetrain undergoes a lot of stress/flex I just met a 3S guy that split his trans thru 2 cases.
While its easy to pick on you, I am not trying to do that here, I am trying to figure out why this would be needed, if you would provide the examples that you seem to know about I would like to see what is exactly happening and what these people are doing, why?
I have a DSM too and I hate when my shit breaks whether it be a few hours or maybe even a day or two.
Old 02-17-2010   #20
CarPsyco84
CarPsyco84's Avatar
Re: T-case bracing?
Why is your T-case all alum? want a cast iron headed one instead?
-When in doubt, Moar RPM.
