Old 03-08-2010   #1
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
3rd cylendar issue?
the first time i blew my motor it would only hold 30% of air capasity in the 3rd cylendar and the secound time i spun a bearing on the 3rd cylendar could this be linked to a certain issue or may be a shitty build? running a 16g 3 inch turbo back exhaust and no tuner stock boost and it blew after 100 miles of rebuild secound time first time had 169k on original motor as far as i know
96GST16g is offline   Reply With Quote
Old 03-08-2010   #2
Re: 3rd cylendar issue?
Shitty rebuild and the fact you don't have a tune is definitely not helping.
Old 03-08-2010   #3
96GST16g
livin the dream
96GST16g's Avatar
yea im not beating on it what so ever i asked the shop that built it and they said i didnt sell you the bearings so not my fault
Old 03-08-2010   #4
If you build motors as good as you type, maybe its time for a virgin stocker Kia even.
Old 03-08-2010   #5
A spun bearing has nothing to do with poor leakdown test results. If you certainly never beat on the car (never hit boost, no revs beyond what is required to shift) then it was a problem with the build.
Old 03-08-2010   #6
96GST16g
livin the dream
96GST16g's Avatar
i didnt build the motor.... and i never went above 3 grand for rpms may be a little bit of boost
Old 03-08-2010   #7
96GST16g
livin the dream
96GST16g's Avatar
and the leak down test was the first time..the secound was pretty obvious with a rod knock
Old 03-08-2010   #8
If you didn't boost it, then it probably isn't a tune issue. Could be an oil pump problem, oil pickup problem, build problem, bearing problem, or some other random or freak thing.
Old 03-08-2010   #9
blackrosenova400
blackrosenova400's Avatar
Sure it can, a spun bearing would prevent oil getting up top, causing cylinder wall scoring. Theres obviously an oil starvation problem somewhere.
20g Mafia
Old 03-08-2010   #10
96GST16g
livin the dream
96GST16g's Avatar
i though contamination? o well what do i know i cant even type or spell good
Old 03-08-2010   #11
96GST16g
livin the dream
96GST16g's Avatar
the first time it blew scored the wall the secound time a bearing spun in the same cylendar i thought it was kind of weird
Old 03-08-2010   #12
I'd say lean a little harder on whoever built it. Just because they didn't sell you the bearings doesn't mean they didn't have to check for tolerances properly. If there was a problem with the bearings, they should have caught it during assembly, simple as that.
Old 03-08-2010   #13
Ok seriously, enough of this. Capitalization, proper punctuation, and proper spelling. These are part of the rules of this site and they are regularly enforced, for good reason.
Old 03-08-2010   #14
blackrosenova400
If I was you I would take a good look at the oil jet for that piston. Also you should tell us how the main crank bearings look like, the one that would be suspect would be the fourth cap back starting at the timing belt side. It feeds the journal for your #3 rod bearings.
20g Mafia
Old 03-08-2010   #15
96GST16g
livin the dream
96GST16g's Avatar
i am sorry that i suck so bad at grammer and spelling... but i scrapped the block and bought a different motor instead. was just wondering if it could be a sensor or wire issue or possible an injector?
Old 03-08-2010   #16
You're all over the place man! How could it be a injector or wiring issue, is there other problems with the car? Did it overheat? Try logging it when its got a fresh motor, check oil pressure, etc. Due diligence goes a long way!
Old 03-08-2010   #17
So does capitalization (especially after being warned twice already). Try it, the [Shift] key is big and fun!
Old 03-08-2010   #18
96GST16g
livin the dream
96GST16g's Avatar
No it did not over heat and for some reason the battery will die over night? I don't think that would be linked to it.
Old 03-09-2010   #19
TurboDomestics
TurboDomestics's Avatar
Sounds like your car has issues man.
Take it to a shop and have them fix it. Or if you want to learn and most likely have to keep repairing the car constantly for the next year, try doing the work yourself.
4G63 0, Charlie 3
