Old 03-10-2010   #1
Good article on torque, horsepower, and gearing
Basic and over-simplified, but gets the brain working pretty good
http://www.jacobmcdonald.com/weblinks/hptq2.html
That article is good, but it is *way* over-simplified. We all know that engines don't produce their peak horsepower through the entire powerband. His logic in the end really would only stand if the theoretical cars were equipped with CVT's and held at peak horsepower.
Still, the logic is fairly sound. More horsepower = more acceleration. But I can tell you, having tons of torque down low just means you have more horsepower through your powerband. My BBK makes over 300whp at 4000rpm, but a SC61-powered car making similar peak power won't make it until 5500. Which car is faster? In the correct situation, mine; I don't have to shift as much to keep on accelerating!
Torque wins races really means having a wide powerband wins races, right? As long as peak output is similar, the car with more torque down low is going to be faster.
Old 03-10-2010   #2
Re: Good article on torque, horsepower, and gearing
Horsepower band, gearing, weight, traction, suspension, and driving wins races. Some high peak TQ is the least important thing, unless you are stuck in the 1960s.
Old 03-10-2010   #3
what's the difference between a 400whp supra and a 800whp supra? :P
Old 03-10-2010   #4
LingLing
AznKraut
LingLing's Avatar
How big the kid's trust fund is?
Old 03-10-2010   #5
So basically, swiftys car wont be fast?
Old 03-10-2010   #6
If the 800hp Supra has a crap driver then nothing. With good drivers, the difference probably would be about 4 seconds.
Old 03-10-2010   #7
Good answer!
Old 03-10-2010   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
The thing most people fail to realize is it's about average wheel thrust after factoring in TQ multipliers (such as gearing, or wheel size) , rather than average engine HP or TQ.
This is one of the better articles I've found over the years that explains the basic concepts:
http://craig.backfire.ca/pages/autos/horsepower
Dyno graphs can be very deceiving because they don't show you the actual wheel force curves for each gear.
-Sebastian Vettel
Old 03-10-2010   #9
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I think you make a valid point, Tachyon, but I think scheides points were mainly along the lines of power and torque distribution. Like you said, scalers bring it down or up, but don't change the shape/distribution of the curves.
Style's automotive engineer
Old 03-10-2010   #10
Tachyon
Tachyon's Avatar
Drives: Icarus
I was more appending to his information, rather then suggesting contrary
-Sebastian Vettel
