Old 03-19-2010   #1
Question about RC brand injectors
I bought some 1000cc injectors used and have them in my quest now, but after resetting the fuel map for them (up from 750cc) and changing them in the battery offset wizard, I have had to add a lot of fuel in the maps just to get them to work.
Is it safe to assume that because I have a base fuel pressure of about 36psi that these are not functioning correctly? Everywhere I look I see that 43 or 43.5 psi is the way things should be, should I just go ahead and set them for that so I have more headroom on the map?
The tables go up to 255 for fuel, and I'm touching 190 right now with only 10 psi of boost. so I kindof want a "shorter" table, if you will.
