Old 03-29-2010   #1
iceminion
iceminion's Avatar
Which pistons are these?
Sorry for the Low resolution, someone is trying to sell me a stock 6-bolt, looking at the pictures, i see a problem:
63D - 1G non-turbo
63T - 1G Turbo
63dT - 2G turbo
Am I correct in assuming that this picture is of a NT engine?
building a 3000GT AWD Turbo.
Old 03-29-2010   #2
Re: Which pistons are these?
Its a n.a.
Old 03-29-2010   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Originally Posted by tkrperformance View Post
its a n.a.
+1
Old 03-29-2010   #4
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
+2 heres some pics i found on talk of a 6 bolt turbo bottom end, http://www.dsmtalk.com/forums/showpo...23&postcount=7
notsostockgalant is offline   Reply With Quote
Old 03-30-2010   #5
BogusSVO
BogusSVO's Avatar
Drives: 1985 Ford Thunderbird Turbo Coupe
well looking at the other thread pics, that should be a 7bolt according to the chart the OP posted, unless its the 1g rods with the 2g pistons...
to the OP, roll the engine over and pop the oil pan off, look for the oil squirters in the bottom of the cylinder. that would make it a turbo block from what I understand.
Or order a set of 1g turbo pistons and rings and slide them into that NA block....
BogusSVO is offline   Reply With Quote
Old 03-30-2010   #6
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
+3 if it really matters at this point. has to be 9:1...
Buy the block and just put some turbo rod and pistons in the beotch
