Old 04-11-2010   #1
b00sted_spyder
2g 6 bolt Lower radiator hose
I've read 1g hose doesn't fit that well because of the shifter counterweight(I think that's what it's called). 2g hose is obviously longer. Which lower radiator hose will I need? Thanks.
Old 04-17-2010   #2
b00sted_spyder
Re: 2g 6 bolt Lower radiator hose
Anyone?
Old 04-17-2010   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Well the car originally came with a 2g hose, so you might as well use the one it originally had. I've never used 1g radiator hoses on my 2g's.
Originally Posted by shoutbox
Old 04-17-2010   #4
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Ur suppose to use the 1g radiator hose and cut off the weight
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 04-18-2010   #5
I used the 1g one and remember having to cut it a bit to fit.
Old 04-18-2010   #6
Yep I cut the counter weight off and run a 1g lower hose.
Old 04-19-2010   #7
b00sted_spyder
Cool, will cutting off the weight affect anything?
Old 04-19-2010   #8
It will just affect how shifting feels, I actually like it without the counterweight.
Make sure you cut enough off so that it doesn't rub on the hose at any point. I also smoothed the newly cut edge just in case, but that's being paranoid.
