Old 04-11-2010   #1
EVo guys, ?? about those 3 little gauges
I don't know if this is evo 8 specific or the 9s have them too.
I know that Stewart warner has replacements for them, but 1. I can't find them and 2. Are there any other companies that make replacements for them.
I am looking for a small boost, water temp, oil pressure.
I tried to search SW site but it sucks and I didn't find anything.
Thanks
Aaron
Old 04-11-2010   #2
LingLing
AznKraut
LingLing's Avatar
Re: EVo guys, ?? about those 3 little gauges
I did some googling and ended up on this website (http://store.42draftdesigns.com/VDO-Gauges_c_11.html) They aren't the SW ones, but these guys have the VDO ones...If that even helps any.
Old 04-12-2010   #3
Yeah thanks. Any clean small gauges will, just need to find the right ranges.
*edit*
I ran those part numbers listed and they are all 2 1/16", doesn't anywhere make good small gauges anymore?
I understand bigger is better to see easily.
Old 04-12-2010   #4
Found an awesome small gauge for you. it tells what direction you are going in, and should be super small for you.
Old 04-12-2010   #5
As far as I know there are no small aftermarket gauges that fit in place of the optional Evo ones.
Old 04-12-2010   #6
Aren't those optional gauges 45mm? If so prosport has them
Old 04-12-2010   #7
Not sure, but if so those would be perfect! I didn't realize Prosport was making tiny gauges.
Old 04-12-2010   #8
yeah i found those late last night and omori gauges.
I wish those 45mm from prosport had the warning function also.
