Old 04-12-2010   #1
Tyc88
Drives: 97 Mitsubishi eclipse gst
My stupid Car won't go into gear
I have a 97 eclipse gst. New clutch new trany and all the works but she still needs to be reved to two grand to get into any gear and first has to be forced. Can any one give me any advice?
Tyc88 is offline   Reply With Quote
Old 04-12-2010   #2
Re: My stupid Car won't go into gear
Are you sure the clutch is working properly? Sounds like it's not fully disengaging which means when the car is stopped and you press in the clutch the transmission it still spinning and won't let the car go into gear.
Old 04-12-2010   #3
Adjust your clutch. My guess is your engagement needs to be raised so its not right on the floor.
Old 04-12-2010   #4
Tyc88
Ok I will adjust it if that don't work I'm going to buy a new one. Any suggestions on a good aftermarket clutch? Thanks for the help btw.
Old 04-12-2010   #5
Didn't you just buy a new clutch? Why not fix the actual problem rather than blinding throwing more parts at it? If adjusting the engagement doesn't help then you'll want to look at your master and slave cylinders to make sure neither is leaking. Its possible the system needs to be rebled too. If none of that works then inspect the pivot points on the pedal assembly. After all that checks out then you may need to confirm the step height on your flywheel was machined properly.
Old 04-12-2010   #6
Tyc88
I have had like three machanics look at it and try to fix it and it's really frustrating.non of them ever really worked on imports but a clutch is a clutch. I'm not sure if they ver adjusted it before but one guy won't even answer my calls cause he is sick of messing with it. I don't know why to do so of buying a new clutch will fix it I'm down.
Old 04-12-2010   #7
Rather than having mechanics with no DSM/Mitsu experience fumble around with it why not just bring it to one of our sponsor shops?
Old 04-12-2010   #8
Tyc88
I'm going to it's just I already paid this dumbass to fix it and I was hoping he could. I stopped at the dealer in Brooklyn parkn and he gve me this web site. I'll call Jim and have them look at it. Thank you dude for your help I'll get ahold of them and I'm sure they will fix it.
Old 04-12-2010   #9
Tyc88
I have to get back to work but thanks again
Old 04-12-2010   #10
Good luck. If the dealership doesn't work out for you we also have DB, MAP, and Primo on here to help.
