Old 04-17-2010   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Oil pump sproket hard to turn..
So my oil pump seized on me after doing my balance shaft delete. I took it apart and found out the stub that came with my kit seized into the housing. I installed it properly and made sure it had plenty of oil. I also primed the car for a long time before I started it.
So now I got a new oil pump/ front case that already had the BS's eliminated. So I swapped the oil pump over to mine but it seems like it's still really hard to turn. I assembled it all with ARP moly lube and even primed it by hand. I got it to turn pretty easily but once I bolted up the front case it was hard to turn again. Even after putting my impact on it and spinning it for awhile. I don't remember it ever being this hard to turn. The only other option I can think of is to put the rear balance shaft back on instead of the stub.
so basically I'm asking is it supposed to have some kind of resistance to it? Like to where it's pretty hard to turn the sprocket by hand? I know the lube will make it a little harder to turn. But I'm almost 100% it wasn't this hard before..
-1990 Mitsubishi Cyborg 4WD-
Old 04-17-2010   #2
CarPsyco84
CarPsyco84's Avatar
Re: Oil pump sproket hard to turn..
That's bad... it should turn freely, something is not fitting right under the front cover or pump cover...
-When in doubt, Moar RPM.
Old 04-17-2010   #3
This may or may not pertain to you but we have here a brand new OEM front cover with a brand new OEM Stub shaft and they do not fit together. The stub shaft does not fit in the hole right. when installed you cannot even turn it. Maybe you had a bad stub shaft or something. But I hope that front cover works for you!
1998 Spyder AWD
567hp
490tq
Old 04-17-2010   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
That's why I'm thinking of putting the balance shaft back in. You can leave the rear one in, and connected. I'll have to try that and see if it spins freely. BTW Mike, how much did you want for that front case?
Old 04-18-2010   #5
Yeah, it should turn freely. Where did you get the stubshaft from? The factory Mitsu one should work perfectly with the Mitsu front case.
Old 04-18-2010   #6
Won't having one balance shaft produce vibrations? You could just get that one turned down. I remember my stub shaft/oil pump was easy to turn, very loose feeling.
Old 04-18-2010   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I bought the kit from Partsdinosaur.com.
No you can leave there rear one in there without any issues. (people say) I could just cut the balance shaft off and use it like a stub. A lot of people do it that way.
I'm gonna put the rear shaft back in and see how it feels. If it feels good I'll either just put it back in, or cut it and use the end of it like a stub.
Old 04-18-2010   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Well even with the balance shaft connected it still had quite a bit of resistance. I ended up assembling it all into the case I got from Primo and it spins freely. I'm assuming something got really messed up with my case when this happened. Maybe even warped it.. After all, I was at about 3k rpm with it seized up.
Old 04-18-2010   #9
So wait, you got a new front case with an oil pump in it, but you took the pump out of that one to put it in the old case? Why not just put the whole new front case on?
Old 04-18-2010   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
The case that came off my car is in a little better condition. The one I got has a few little hair lines cracks here and there. It doesn't appear that they go through at all though. Just kind of have a habbit of trying to keep my original stuff on my car.
