Old 05-05-2010   #1
2g Monson
2g Monson's Avatar
Drives: 1995 Eclipse GST
Car barely moves and makes terrible noise
Well this goes along with the terrible month for mitsu's. Last night I go to drive my car. When I put it in gear and let the clutch off and give it any gas it makes a loud clunking/ grinding noise from the left front. After trailering it home it wouldn't even move. I took it apart and none of the splines are wore away on the axle and no shavings are in the tranny. My dad looked at it as i was pulling it off the trailer and said half the axle was spinning. So the transmission was turning but it wont turn the wheels.
Any ideas?
Tomorrow I plan on looking for a used axle just to see if it will fix it. It never did it before last night.
2g Monson is offline   Reply With Quote
Old 05-06-2010   #2
santa
Boost Spike
santa's Avatar
Re: Car barely moves and makes terrible noise
Any ideas?
Center diff blew up is my guess. Do you have the transmission out yet?
Old 05-06-2010   #3
2g Monson
2g Monson's Avatar
No, I don't have it out. Its on a 95 n/t daily beater, I wouldn't think it would have enough power to wreck anything internally.
Old 05-06-2010   #4
If the axle is spinning but the wheel is not, it's a broken cv joint.
Old 05-06-2010   #5
2g Monson
2g Monson's Avatar
Thats what I was thinking, but I took the boot off and it doesn't appear to be damaged. Theres a little play in it but didn't seem like it would be enough for the noise it makes
Old 05-06-2010   #6
Well if you said the splines on the axle and in the spindle are good, then it can only be the axle
Old 05-06-2010   #7
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
thats happend to me before, its the axle
Old 05-06-2010   #8
santa
Boost Spike
santa's Avatar
lol I was assuming it was a awd for some reason. My bad lol. Broken cv joint sounds right. Are the boots ripped?
Old 05-06-2010   #9
2g Monson
2g Monson's Avatar
Good thing an axle is a cheap fix, I hate putting money into this thing as is. And nope, no tears or anything in the boot. It was just weird taking it apart and not seeing any obvious damage
