Old 04-22-2004   #1
jd1828
ever since i did the crankcase and pcv vent mod the engine has slowly started to leak oil from the valve cover and a lot from the oil pan. this is on a engine with all new gaskets that didnt leak a drop of oil before the pcv mod.
i remember i was talking to someone on here that said they used a vacuum pump on their crankcase. where can i get an electric pump? all i can find is the belt driven ones. how much oil does the pump pull out of the crankcase?
Old 04-22-2004   #2
The vacuum pump will pull air out, not oil. It will keep the crankcase from building up preasure, it is supposed to help performance and it may keep oil from leaking out of gaskets due to less internal preasure.
Old 04-22-2004   #3
jd1828
it should still pull out a little oil just like the stock crankcase vent does.
Old 04-22-2004   #4
I suppose it would, but i doubt it would be very much...nothing worth noting. The pump's main purpose is air.
Old 04-22-2004   #5
jd1828
i looked around a little more and found a list of cars that came with pumps on them. the only probem is they are all early to mid 1980's. so might be kind of hard to find one in a junkyard or even find one that still works.
Old 04-22-2004   #6
Jacek
Captain J-Sack
try to look in big trucks.
Old 04-22-2004   #7
Raptor
ConArtist
Raptor's Avatar
Why the hell would anyone do that?
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 04-22-2004   #8
Jacek
Captain J-Sack
do what?
Old 04-22-2004   #9
Raptor
ConArtist
Raptor's Avatar
why would anyone use a vacuum pump, sounds just silly to me.
651-488-7774
Old 04-22-2004   #10
jd1828
its just another one of my weekly dumb ideas. i do remember hearing about someone doing this. i just cant remember who it was.
Old 04-22-2004   #11
Raptor
ConArtist
Raptor's Avatar
No one is that stupid.
651-488-7774
Old 04-22-2004   #12
jd1828
i agree. you seem very opinionated on the subject
Old 04-22-2004   #13
Raptor
ConArtist
Raptor's Avatar
Jason, I am kidding I told you about the pump a while ago remember. Anyway, the one I used was from a diesel escort of all things. It is 12 volt and pulls a nice 15". Hope that helps. It was like 7 bucks at u-pull-our-parts
651-488-7774
Old 04-22-2004   #14
jd1828
:razz2: i thought it was you
how has it been working for you? do you have it so its on all the time or just a toggle switch. i was thinking of using a relay hooked up to an igniton line so that its always on. either that or a hobbs switch so that it only comes on when i really need it.
