Old 05-17-2010   #1
Chim55117
Drives: 2007 BMW 335i Coupe
Ratio for Redline Cocktail
Hey guys, I have the Redline Cocktail from the drawing on Saturday, and I was wondering how to go about using it in terms of the ratio of the MT90 to the MTL.
I have:
2qt - Redline MT-90
1qt - Redline MTL
So, what I'm asking is, should I pour in two of the MT-90s first, then add the MTL, or add the MTL, and then add the MT-90s? And will there be leftover fluid? The transmission is a 1992 Mitsubishi Galant transmission.
Thanks for all the help in advance, and thanks again guys for donating, so the Redline Cocktail could be available as a prize!
- Stephen
Chim55117 is offline   Reply With Quote
Old 05-17-2010   #2
Re: Ratio for Redline Cocktail
Use one full bottle of MT-90 and MTL, then use the 2nd bottle of MT-90 to top it off. You should have a little bit left over.
Old 05-17-2010   #3
Chim55117
Thanks Kracka!
Old 05-17-2010   #4
I usually mix all 3 together in a seperate container. Fill up the tranny, and use the leftover in the transfer case.
