Old 05-19-2010   #1
smoothgangsta
Drives: 2006 Lancer Evolution IX GSR w/SSL
WORKS Spin Aluminum Flywheel and OE throwout bearing
Have a couple of things for sale, not sure if there is any interest.
(1) OE throw out bearing (never used, 2 weeks old)
(1) WORKS spin lightweight aluminum flywheel with replaceable steel frictions surface, specs are here -
http://www.worksevo.com/store/produc...products_id=38
The OE throwout bearing is new and came with the Fidanza kit. I had ordered a new one before I saw what came in the Fidanza kit and it turns out that the one Fidanza includes is identical to the the Mitsu OEM throwout bearing.
In regards to the flywheel, I decided this time not to put the Works spin aluminum flywheel back into my car because I got sick of my wife b****ing about how difficult it was to drive the car, so I opted with the recommendation from Chris at MAP to put the Comp lightweight steel flywheel in instead, and now momma is happy.
The flywheel has the replaceable steel friction surface. The specs on it are 4.2kg (approx 9.25 lbs.). It has approximately 60k+ miles on it and I have some new flywheel-to-crankshaft bolts coming from Works, assuming someone buys it they can order the replacement steel friction surface from Works for around $90.00.
Anyway, if interested make me an offer.
smoothgangsta is offline   Reply With Quote
