Old 06-01-2010   #1
88_Colt_GT
Drives: '88 Colt GT
clutch upgrade for '89 colt GT (turbo)
I have a 1.6 and my clutch is slipping and makes my happy gauge go down.. I would like to upgrade it while i'm in there. does anyone know what clutch will transfer over?
These are the OEM specs from oreillys site:
Outside Diameter: 8.5"
Inside Diameter: 7/8"
Teeth: 20
I have the 4g61 with a 5-speed, FWD. Thanks!! Also if anyone has a compatiable clutch that they have for sale, please let me know.
88_Colt_GT is offline   Reply With Quote
Old 06-01-2010   #2
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: clutch upgrade for '89 colt GT (turbo)
It should be the same as the fwd dsm's I think. I haven't done a colt though, so don't quote me.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-01-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
If its the same as a FWD dsm then it would be the same for any DSM. Only difference is in the flywheels. I'm wondering this too cause I'll probably need to upgrade mine once the turbo goes on.
-1990 Mitsubishi Cyborg 4WD-
Old 06-01-2010   #4
88_Colt_GT
Drives: '88 Colt GT
From O'reilly's website, under compatiability.
1990-1994MitsubishiEclipse
[GS] L4 - 2.0L vin R 122ci 1997cc - MFI GAS DOHC
[GS] L4 - 2.0L vin U 122ci 1997cc - MFI GAS DOHC Turbo-charged
[GS] L4 - 2.0L vin E 122ci 1997cc - MFI GAS DOHC
[GS] L4 - 2.0L vin F 122ci 1997cc - MFI GAS DOHC Turbo-charged
[GSX] L4 - 2.0L vin U 122ci 1997cc - MFI GAS DOHC Turbo-charged
[GSX] L4 - 2.0L vin F 122ci 1997cc - MFI GAS DOHC Turbo-charged
so this means I can find an aftermarket clutch for a 1st gen eclipse turbo and it should be the same. It just wont be marketed as one for a '89 colt gt. (I made the wrong screenname, can admins edit that or no?)
Old 06-01-2010   #5
the oem 1.6 clutch is not the same as a dsm. your best bet is to get a 6bolt turbo fwd flywheel and a dsm clutch and be done with it
the 1.6 is just like a n.a. flywheel and clutch
Old 06-02-2010   #6
123abc's Avatar
Drives: Loud cars
You'd need to swap transmissions then, wouldn't you?
Old 06-02-2010   #7
johnson
johnson's Avatar
Drives: 90mitsu
I believe you would use the awd flywheel with the stock 1.6 tranny as its housing is a lot smaller than the fwd?
Old 06-02-2010   #8
with the stock 1.6 turbo tranny you need to use the fwd turbo fly wheel.
the 1.6 tranny and the 2.0 turbo tranny are the same trannys for the most part.
Old 06-02-2010   #9
x-pride
x-pride's Avatar
Hope this answers your question.
http://www.4g61t.org/forum/viewtopic.php?f=2&t=13
