Old 06-04-2010   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Clutch help
95 talon awd 5 sp.
Stock tranny
stage four comp 6 puck
New tb and I beleive resurfaced flywheel
The issue that I'm having, is after driving 100 or so miles the clutch wants to slip. So the solution for now is bleeding my clutch every night. After bleeding clutch everything is back in order, clutch engages is close the the floor and is soft again. Then after 100 miles, clutch get hard and engages near the top, and that when it slips. Car is currently only running 18 lbs of boost, if that matters and only slips really under boost. I've researched other threads and came up with nothing. If you needore info on the car or conditions of driving let me know.
Thanks in advance
