Old 06-09-2010   #1
Torque for Rod Caps with ARPs
Ok, so i wanted to get an opinion on this. I havent dropped the pan yet but i have the feeling the bastard loosened again. or more-so, in the case that it has i would like to know what you all think.
The rods are Manley I Beam baller ass rods, they come with ARP 2000 rod bolts for the caps. Im using the moly lube on the bolts. When i built the motor i torqued it to the factory setting. Everything should have been perfect. I believe i was told it was 38 ft lbs. (if its not dont flame me, it was a while ago that i actually torqued them).
If the case is that the bolts came loose again, should i look into torquing it higher? I know the torque wrench is accurate, its a brand spanking new craftsman torque wrench.
Anyways, What do you guys think, Is this like the ARP Headstuds where i should be torqueing much higher than stock, or what?
Thanks in advance,
Tom
Old 06-09-2010   #2
Re: Torque for Rod Caps with ARPs
Did you not use Plastigauge? That will tell you what the torque spec is.
Old 06-09-2010   #3
I reused my ARP rod bolts and retorqued them to 42 ft-lbs I think. I doubt they came loose on you already, unless you forgot to torque a couple.
Old 06-09-2010   #4
Yeah im absolutly positive i torqued all of them.
Old 06-09-2010   #5
How would a plastigage tell you what the torque spec is? It only tells you what the clearence is between the bearing and the shaft?
Old 06-09-2010   #6
The more torque there is holding the pieces together the less clearance there will be. Just because it says such and such a torque doesn't mean the clearance is correct, and improper clearance is what can make bearings fail.
Old 06-09-2010   #7
Tom, did you make sure you kept the same rods with the same rod caps? That is very important as well. And make sure you didn't put some on backwards?
For some reason I thought I heard someone say they didn't think matching the caps to rods was a big deal, and I'm almost positive you have to keep them the same, just like cam caps, they're machined to be a perfect fit for each other.
Old 06-09-2010   #8
Yes all of the rods were kept with their respecitve caps. And im sure the caps were placed correctly (notches on the oppisite side of each other.)
Im pretty sure one of the bearings just failed (i have a good idea which one). Ill just replace them.
Old 06-09-2010   #9
You need to know which bolts they came with.
http://www.arp-bolts.com/Tech/TechTorque.html
Old 06-09-2010   #10
blackrosenova400
blackrosenova400's Avatar
You only check bearing clearances using a plastigauge. Not for bolt torque.
The correct way of tightening rod bolts is using a stretch gauge or maybe a micrometer to check how much the studs have stretched. Also some rods come with differant studs/bolts so you have to figure out what bolts you have to figure out torque value if you choose to use that method.
20g Mafia
Old 06-09-2010   #11
http://www.maperformance.com/manley-...ting-rods.html
These are the rods i have. It says they come with 3/8" ARP 2000 Bolts.
Old 06-09-2010   #12
Did you try taking that info to the ARP paged I linked?
Old 06-09-2010   #13
I looked on the page but all i could find is the Mitsubishi rod cap bolts, but there was no mencion of the series bolt.
and if thats the case, then i torqued them to the correct specs. So hopefully it was just the bearing messed up i will hope for the best.
Old 06-09-2010   #14
If you look on that page they show specific part numbers of the bolts. You need to contact Manley and find out which bolt they used in your rods. Then you will know which torque spec is correct.
Old 06-09-2010   #15
Thanks Vicious, ill do that.
Old 06-09-2010   #16
Now go have mad monkey sex with your fiance'.
