Old 06-15-2010   #1
travail
travail's Avatar
Drives: EV0 8
Evo went under the knife
Well I found out that I have to put in new main bearing so out came the motor and the tran. But now I can clean up the engine bay and so on. I will up date when ever I can.
travail is offline   Reply With Quote
Old 06-15-2010   #2
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Evo went under the knife
did you end up being able to pullit out the topside?
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 06-16-2010   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Considering that the motor is hanging from an engine hoist and the car is on jack stands as opposed to a lift, I think it is safe to assume it was lifted out of the car.
7/25/09
Old 06-16-2010   #4
travail
travail's Avatar
Drives: EV0 8
Yes it came out the topside and it was not that bad.
Old 06-16-2010   #5
mike55112
mike55112's Avatar
Drives: 04 evo
I have pulled my engine I think 4 times and I have always dropped it out the bottom.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-16-2010   #6
If you've got a lift, out the bottom would be easy. If not, it would be pretty difficult.
Old 06-16-2010   #7
mike55112
mike55112's Avatar
Drives: 04 evo
I did it without a lift twice and still dropped it out the bottom, once without a engine lift even. I didnt have the head on once.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-23-2010   #8
travail
travail's Avatar
Drives: EV0 8
Well I started to clean up the engine bay
and then I found this. I was llike WTF this is why you never drill a hole in the firewall with looking first.
The motor and tran coming apart
and then the main bearing.
Old 06-23-2010   #9
That's crazy that someone drilled through the wiring harness like that. Make sure you inspect all those wires!
Old 06-24-2010   #10
travail
travail's Avatar
Drives: EV0 8
Yes I look at all of them
Old 06-24-2010   #11
travail
travail's Avatar
Drives: EV0 8
up date
Took the motor and tran apart tonight. The in side of the tran was very dirty.
Looks like there are little crack in the pressure plate
Then I saw this some one welded on the pressure plate
Clutch look like it was starting to go bad and I plan on getting a ACT HD STREET 6 CLUTCH it's good for 508 ft/lbs
at lest the fly wheel look ok but I plan on getting a FIDANZA fly wheel
