Old 06-16-2010   #1
2zzgtte
The Russian Stub
2zzgtte's Avatar
Drives: 2001 Celica, 2005 Evo
Evo 8 fuse diagram
Anyone have the cabin fuse diagram. The one that is right underneath the steering wheel? I can't find that thing anywhere. I looked in the manual and it tells me to go to a certain page and the page is not there. I think one of my fuel pump relays went out.
Any suggestions on how to test these or where they are at?
2zzgtte is offline   Reply With Quote
Old 06-17-2010   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Evo 8 fuse diagram
Do you have power at the fuel pump?
Old 06-17-2010   #3
cmspaz
Walls need hugs too
cmspaz's Avatar
EFI fuse is under the hood, I'm fairly certain the relay is up there, too.
Originally Posted by Trogdor
Old 06-17-2010   #4
2zzgtte
The Russian Stub
2zzgtte's Avatar
I do not think so. I do not hear the fuel pump turn on when I turn the ignition. I looked under the hood and the diagram that is on the back of the cover (the little pictures that are associated with each location on the fuse/relay) shows nothing about fuel or anything like that. Unless I am mis-reading it...
I need to figure out how to test my connection. I am assuming that I have no power to the fuel pump. Anyone got any directions on how to test something like that? I was thinking one of those little things that you put close to a plug socket in your house and it beeps if it has power to it??
Old 08-11-2010   #5
2zzgtte
The Russian Stub
2zzgtte's Avatar
Alright. It has been a while. Still have not got this issue fix. I am not getting power back to the fuel pump. 95Talonracer and I have been looking at the Evo and we tested:
Swapped out relays under the hood with good relays. Not that.
Crank position sensor. That looks good.
injector resistor pack. Thats good.
We tested spark and it has spark.
It has no power back to the fuel pump.
Checked wire harness by driver side kick panel. Looks good.
What else could it be?
Old 08-11-2010   #6
Are there any blown fuses?
Have you done this to make sure the pump works?
Old 08-11-2010   #7
When are you checking for power? Power to the fuel pump don't come on until you start cranking the motor, it doesn't prime at all on the Evos with key on. The fuel pump fuse is in the fuse box in the engine bay, it is one of the ones with an engine picture.
Old 08-11-2010   #8
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Thats exactly what I have been looking for for over an hour and i tryed to search everywhere! Thanks John!
Amsoil Dealer
Old 08-11-2010   #9
95talonracer
Finally Tuned...
Drives: Spyder GSX
I checked all of those fuses and yes we checked for power when cranking over the engine.
Amsoil Dealer
