Old 06-25-2010   #1
bob123131
Spring cleaning shoot me any offer
Im in coates mn if you pick it up, i will take any reasonable price or decent lowball for most things just want it gone.
2g steering column
brake booster and master assembly-no lea-non abs
Radiator and fans
Air boxes
FWD gas tankwith sending units, pump, and pigtails, and filler neck
dash harness's-20
Main dash harness, passenger side connector is cut, but will be included
Heater core with whole box
Power steering resevoir and all high pressure low pressure lines, with front coller loop
Cold air intake with filter for 4g64-
Front subframe with all arms, knuckes, spindles, brake assembly's, calipers and soft brake lines, sway bars, front rear motor mountbraket. will seperate
Blower motor with box assembly
Master cyliner with resevoir- no leaks-
Full exhaust and headers 2 1/4 split to dual in the back with i think ebay cans
oem rear taillights and middle peice
Non turbo Gauge cluster 88k miles with white backed gauges-
two pillar a
enkei rsf-2 Wheels all four no curb rash tires have 20 percent thread-225
pneumatic air cylinders no dampers custom oe fit brackets,
dual mechanical air gauges for air ride up to 150 psi
2g spyder shell down to bare metal, prolly not worth much as a car, but if you need a rear corner or front clip etc its rust free
2g climate controls
Nice rear tonneau cover that goes above back seats formed to shape seats-300
fwd rear subframe with ebrake stuff etc and knuckes and spindles-will seperate all like new
2 doors with handles shaved-
oem hood primed-
95 96 headlights great condition-
Full 95-96 bumper, door skirts and rear bumper-seen better days but cheap
blitz front bumper-40-good condition, but some of the holes for bumper bolts
All modules turn signal control module, security module, cruise control,
Driver side seat covered in weird upulstry
2g fenders primed for paint
Below stuff prolly wont take mega lowball
1g 6bolt 4g63 full engine wit bent valves
all engine sensors and electronics
1g torque converter
2g fwd fidanza flywheel resurfaced and balanced
1g auto tranny works well
4g63 auto ecu
set of extra 1g internals
1g cooling fans
-RC car-ofna monster pirate with the .21 ofna hyper turbo engine-ran recently
bob123131 is offline   Reply With Quote
