Old 06-26-2010   #1
olson3422
Drives: 92 laser
ecu's ????
what has to be done when putting a 90 ecu in a 92
olson3422 is offline   Reply With Quote
Old 06-27-2010   #2
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Re: ecu's ????
I don't think anything, just make sure it is the right md# for your car, check this v-faq http://www.vfaq.com/mods/ECUs.html
Old 07-08-2010   #3
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: ecu's ????
Pin 14 Air flow sensor active filter reset (idle switch)
(switch with 6 if using a 91-94 ECU in a 90 or vvs)
Stock wire color - Green
Pin 6 Idle position switch
(switch with 14 if using a 91-94 ECU in a 90 or vvs)
Stock wire color - Green/White
Switch pin 6 with 14 and drive on.
http://www.vfaq.com/index-main.html
