Old 07-08-2010   #1
1g_talon
Drives: 1g talon awd
Thumbs down cant go in gear
like the title says. i cant go into any gear when the car is on, but i can go in when the car is off.
i just put in brand new act 2600 clutch and disc/TOB. right after the new clutch is in, it wouldn't go in any gear. i try adjusting the clutch, new slave cylinder and try bleeding the hydrolic lines and the slave but nothing. the slave rod is pushing the fork/pressure plate so i am guessing the bleeding is correct.
looking at the fork and inside the boot, i can see the pressure plate moving/vibrating. is this normal?
anyone please, please help me on this one. i took the tranny off four times already.
1g_talon is offline   Reply With Quote
Old 07-08-2010   #2
Re: cant go in gear
did you shim the pivot ball, is the fly wheel stepped for the act clutch
Old 07-08-2010   #3
Re: cant go in gear
put it in gear and push the clutch in and start the car. if the car wants to move or does it is not shimmed right.
Old 07-08-2010   #4
1g_talon
Re: cant go in gear
what do you mean shim the ball. is it putting washers behind the pivot ball. i did put one washer behind it though.
first when i took the tranny off, i didn't resurface the flywheel, it didn't go in gear. the second time i took the tranny off, and i had the flywheel resurface to .610 as stock i think, and still not going into gear.
the clutch pedal is bypass so that i wouldn't have to press it when starting the car.
i already try putting in gear and started the car up. but i heard some thing scratching/rubbing and i can smell burn. i took everything apart and found out that there's burn on the disc and pressure plate. also the act tob was scratching the finger's on the plate but not much.
Old 07-08-2010   #5
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Re: cant go in gear
You should use a oem tob and not that act one
Old 07-08-2010   #6
blackrosenova400
blackrosenova400's Avatar
Re: cant go in gear
Your problem is clutch adjustment. Your clutch is not fully releasing and is causing you syncros to drag. Do not drive it or try to force it into gear, you will break a shift fork and you are also dragging/wearing your syncros out quickly!
Shimming your pivot ball is not for adjustment, its to make sure the end of the clutch fork has enough travel to release the clutch before it makes contact with the bellhousing. It may be your problem, hopefully not. Make sure the fork is at least in the middle of the hole or towards the engine when released.
20g Mafia
Old 07-08-2010   #7
1g_talon
Re: cant go in gear
i've try almost anything i could think of. but still cant get it in. i've even try putting two washers behind the pivot ball also.
clutch fork is sitting in the center.
anyone know anything about the pressure plate vibrating. because my pressure plate is vibrating up and down very fast. if i try to stick a stick to touch the plate, it'll buzz like a machine gun going off but not loud. lol..
Old 07-08-2010   #8
1g_talon
Re: cant go in gear
next thing i can think of is bringing it into a shop but they charge a whole grip.
Old 07-08-2010   #9
Re: cant go in gear
Got to pay to play. If not take it off and get some pics and we can try and help.
Old 07-08-2010   #10
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: cant go in gear
I know it sounds dumb but did you put the disc in backwards?
Old 07-08-2010   #12
Spikesoftail
Spikesoftail's Avatar
Drives: 96 Talon Tsi AWD Auto
Re: cant go in gear
Make sure the pilote bushing is installed correctly (or at all) that could give you some gnarly vibration
Spikesoftail is offline   Reply With Quote
Old 07-08-2010   #13
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: cant go in gear
Get an extended slave cylinder rod?
And is .610 a step for ACT clutches? I thought they were different.
-Colin
Old 07-08-2010   #14
1g_talon
Re: cant go in gear
i adjust the clutch so that there aren't any play on the clutch pedal. tob and disc is install correctly.
