Old 07-14-2010   #1
latof
Drives: Stock 95 GSX
Really low oil pressure
My friend rebuilt a 6 bolt block for the one that blew up in my 95 gsx. So we swapped out the engine, and now i have really low oil pressure. He says he is sure that he forgot to do something with the bolt to the crankshaft that allows oil to flow through it. I was wondering what that bolt is called, and what i would have to do to get at it and what to do to it in order to make sure my bearings don't wear on the crank and blow the engine up again. please post pictures if you have any idea what i am talking about.
latof is offline   Reply With Quote
Old 07-15-2010   #2
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Really low oil pressure
This Sounds Like Its Going To Be A Problem. Is He Referring to The Main Bearing Cap Bolts Rod Bolts. . . .a little bit more detail will help pin point the potential problem a lot faster.
Old 07-15-2010   #3
blackrosenova400
blackrosenova400's Avatar
Bearings installed wrong or blocking oil flow will INCREASE oil pressure, sounds like you have a differant problem.
20g Mafia
Old 07-15-2010   #4
blackrosenova400
Do you have a balance shaft elimination? Maybe he forgot to install the block off bearings or rotate the old bearings?
20g Mafia
Old 07-16-2010   #5
latof
Yeah, the balance shaft is eliminated. I cant remember if he said the bearing just needs to be rotated, or if he forgot to put in the block off bearing. Do you think it's possible to jam a dowel pin into the hole to block it off? if so, does anybody know the exact diameter of the hole? If you do, i could just machine a pin to fit into it. Or if i could machine a large plug to just shove into the place of where the balance shaft goes into.
Old 07-17-2010   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
what are you going by to determine low oil pressure?
Style's automotive engineer
Old 07-17-2010   #7
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Just slap on a BB turbo.
No need for a restrictor! ZING!
-Colin
Old 07-18-2010   #8
latof
I was going by the oil pressure gauge, and I know the connection is good so it wasn't that. But I solved the problem in under 4 hours. All I had to do was take off the front bumper cover, front mount, radiator, and alternator. Then I removed the threaded phillips bolt from the block, then i just used a drill bit just under .223" in diameter at 2.3" long and tapped it in the bearing hole, using the back end of the bit to go into the oil hole. Then I put the threaded bolt back in, and put everything back together, and now everything is running smooth. But i would suggest using an actual dowel at a little over 2.4" just to be safe, I know im safe with what I used, but just to be safer, i would go with a little longer. The phillips bolt was kind of stripped, but I was able to get the phillips bolt out by using a ratcheting phillips screw driver that when you hit it with a hammer, it ratchets at the same time (that tool saved me a lot of time but i wish i knew what the actual name for it is called :/)
Old 07-18-2010   #9
s1ngletracker
Drives: A BMW
impact screwdriver
Old 07-18-2010   #10
latof
impact screwdriver, thank you s1ngletracker
Old 07-18-2010   #11
CarPsyco84
CarPsyco84's Avatar
Clever. Usually you just pound out the bearings for the balance shafts out (the balance shaft makes a nice punch for pressing them out). Then rotate them so the oiling holes don't line up any more.
-When in doubt, Moar RPM.
Old 07-18-2010   #12
latof
Yeah, but the balance shaft wasn't assembled with the engine, and my friend forgot to put the bearing back in, but luckily all i had to do only took 4 hours and the sacrifice of a drill bit with a diameter just under .223" without having to take all the crap of the front of the block.
Tags
crankshaft, engine, oil pressure
