Old 04-28-2004   #1
Darth_Laser
Send a message via AIM to Darth_Laser
Hah!
i am so happy, i finally got my laser to start again. When i got it back from elite it just plain wouldn't start! so I jangled around for nearly a week and BOOM! it runs again, thanks to everyone who had given me suggestions in my previous posts! Look for me rockin out with my cock out!
Andy :jammin:
Darth_Laser is offline   Reply With Quote
Old 04-28-2004   #2
Enes
Enes's Avatar
too much info about rocking out...
what was wrong with the car?
-E
Old 04-28-2004   #3
Cool, what was the problem?
Old 04-28-2004   #4
Darth_Laser
Well, it is a little difficult to pinpoint exactly what it was but I believe it happened when i was cleaning the terminals and clamps with a wire brush, or when i cleaned the ground with steel wool? I believe that was it! Now only if I would have thought to do that sooner... :headache:
Otherwise, i was wondering, kinda off topic though, can corrosion on the terminals make your battery and alternator seem as if they are dead? perhaps i may be in the market for an alterantor otherwise!!
Old 04-28-2004   #5
I would say yes and no. No: If there is a little bit of corrosion on the terminals it is still battery acid and should conduct electricity. Yes: If enough battery acid has drained out where your battery cannot store enough energy.
First step to do is clean off your terminals with a bettery brush. Next, pop the fill cover off (if it has one) and check the fluid level. If it is low, you can substitute water (I have only used distilled) for battery acid and fill it up. Charge the battery (on a charger or your car). Bring the battery or the car over to checker and have them test it for you. They will tell you if the battery is in good condition. If it is fine and you still have problems, check you alternator fuse and your alternator.
Good luck.
