Old 08-08-2010   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
650s 2g MAS and old skool 5 knob problems
I am running a 2g MAS, 650s, and a 5 knob safc to correct it out a little in a 1g
First will this combo work? I turned down the fuel pressure a little but even though the 5 knob is a little crude, figured it would work.
However I am running RICH. It will start right up but after that the AFR just peg to 9.6. I am getting a check engine light that turns on and I am wondering if I am having a MAS problem. Do they go bad? Are all 2g MAS the same? Maybe I didn't get one from a turbo car...
