Old 08-14-2010   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
1g transmission and axles, EPROM, AIT/3Bar Gauges
NEW PRICES!
I have 1 90 FWD transmission for sale. It is stock and used. I havent personally used it but I got them from a member on here that is not shady at all. $100
1g 91-94 EPROM ECU, socketed and new caps, looks BRAND NEW $200
I also have a AIT with GM 3 Bar for speed density, It is plug and play into a 1g harness. $80
Apexi EL temp gauge peak/hold memory electronic one (no need for seperate control unit.)(Oil Or Water) $70
I also have axles from a AWD 93 that I would be willing to sell for $80
Please PM me or Call/text at 651-260-5264
Thanks,
Colin
Old 08-14-2010   #2
slowboy101
slowboy101's Avatar
Drives: 91' Eagle Talon TSI
Re: 1g transmission and axles, EPROM, AIT/3Bar Gauges
where did you get all of this stuff you dont even have a DSM
slowboy101 is offline   Reply With Quote
Old 08-14-2010   #3
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Yes I do, when is the last time you were over? Haha its sitting in the driveway..
-Colin
Old 08-21-2010   #4
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
bump new prices
Old 08-21-2010   #5
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
What is the range of the boost gauge? vacuum, max psi
Old 08-21-2010   #6
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
I am pretty sure it is the 6103. Mechanical 270 degree sweep, boost goes up to 30 and vacuum goes to 30 also.
So 30 vacuum to 30 boost.
I will make certain when I get home which one it is.
-Colin
Old 09-06-2010   #7
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
bump new prices!
-Colin
