Old 08-16-2010   #1
new list of parts in my garage
having a moving fire sale on it all. everything I dont want to keep for my self will be taken to the scrap yard for cash in 2 weeks. All good offers taken
1g stuff bins garage
3. awd bearing case 10.00
5. 22 spline out put shaft 15.00
11. fwd starter plate 10.00
14. front lic. plate bracket 10.00
28. power steering pump with pully 20.00
30. 5 speed speedo sensor x2 5.00 each
31. non radiator cap upper t. stat housing 10.00
32. drivers white door handle 5.00
33. drivers greed door handle 5.00
34. pass red door handle x2 5.00 each
2g stuff bins garage
1. lower radiator metal mounts 10.00 set
2. battery tray 10.00
10. knock sensor 25.00
14. upper auto tranny mount alum/rubber x2 20.00 each
21. black review mirror with map lights and wiring 20.00
28. din pocket under raido 5.00 x2 each
37. 7bolt ofh non coolant ofh 10.00
39. awd right rear knuckle 95-96 50.00
53. clutch resavor w/bracket 5.00
4g63 stuff bins garage
1. lower timing tin 10.00
4. power steering heat sheilds x2 10.00 each
5. rear engine lift mounts x2 5.00 each
6. front engine lift mount 5.00
7. alt. arm brackets x6 5.00 each
8. lower fuel pump holder bracket 5.00
16. rear main seal housings x2 10.00 each 7bolt
17. crank balance shaft belt pully x3 10.00 each
18. crank timing belt pully x4 25.00 each
19. oil pump timing belt pully x4 20.00 each
20. crank trigger plates x2 5.00 each
24. oil dip stick tubes x8 5.00 each
mirage/miss stuff bins garage,after market
1. apexi safc mounts ect x2 10.00 each
2. 93-01 mirage raido brackets 10.00 set
3. 89-92 mirage raido brackets 10.00 set
6. evo 1-3 power steering set up no pump 50.00
9. Pte 6776 divided t4 3in vband out. 10an drain fitting,4an feed fitting. 600.00
10. clifford consept 600 alarm 50.00
2g basement shop bins
1. black steering wheel with air bag and cruise non leather mint 40.00
12. lower battery brackt bolts to frame 10.00
33. red gas door 10.00
36. grey map lights w/bracket 10.00
85. key less entry ecu 15.00
87. spyder top control ecu x2 15.00 each
104. new reman upper right control arm front 15.00
105. tan cloth rear spyder seat
