Old 08-16-2010   #1
Part Out - 10sec 600hp 1991 Talon AWD
keep all the questions, requests, etc IN THIS THREAD if possible . Please don't PM me saying you want this and that because it gets very confusing. I'd like to keep as much as possible in this thread. Or if you absolutely need to, you can PM me or call me at 612 384-1425
3" Vibrant resonator - $40
Forge BOV (pretty sure I have the spring kit for this as well for various psi setups) - http://mitsustyle.com/forums/attachm...2&d=1233977461 - $95
Universal Coolant Overflow bottle - $15
Greddy white face EGT gauge and probe (appx 6 years old) - $35
Beatrush solid driveshaft bushings, brand new (fits EVO and DSM) - http://www.maperformance.com/beatrus...051pmb-2t.html - $40 - Pending Sale
10" Hayden Fan - few years old - you can see a pic of it laying on the floor in the 3rd picture of the motor above - $10 - Pending Sale
Starter - $10 - Pending sale
Feel free to make offers if you feel something is priced too high. I feel like I priced it all very competitively, but am willing to listen to offers.
Items that have been sold
Eagle/Mahle 2.0L short block originally built by MAP, E85 has kept the piston tops pretty deng clean. Compression was 165 across all 4 before removed (this was with 272's installed), exterior of block was painted black by MAP - Please contact me via phone or pm for more info regarding this - What is pictured is what you will be receiving (minus the knock sensor), which is why I took pics at different angles - $800 - Sold
HKS 272's - $275 shipped - Sold
17x8 35 offset Rota Boost rims (bronze) w/ Sumitumo HTR Z3 tires (235/45) - tires are nearly new, lots of tread left - $675 - Sold
ETS FMIC 3" thick, about 1 year old, still looks damn near new - $360 shipped - Sold
3" Pypes resonator - $40 - Sold
3" Magnaflow muffler w/ tip - $40 - Sold
PLX Wideband - will include a used and brand new sensor - $190 shipped - Sold
SW white face Boost gauge 30-0-40 (1 year old) - $45 shipped - Sold
Stock 6-bolt flywheel & A/C bracketry - $20 - Sold
SS Turbo oil feed line - - Appx 3 years old - $10 - Sold
Eibach Sportlines w/ KYB AGX's - $375 - Sold
Tial 44mm Wastegate ($300 new) - $210 shipped - Sold
SLS T3 Mani - lifetime warranty - $425 - Sold
S362 (.70AR t3 V-band out) - Turbo has the normal little bitty shaft play. Will include the push-lock drain line, as well as the drain and feed adapter fittings. Feed line not included - short vid available upon request but please only ask me to send it if you are seriously interested - $625 shipped - Sold
Two 10" FAL fans- $35 - Sold
Pair 6x9's - $20 - Sold
Mishimoto Rad Cap - $15 - Sold
Aeromotive AFPR kit from Import Evolution - $120 - Sold
Taylor 10mm plug wires - will include a new set of 4 NGK plugs for free with these - $40 - Sold
Powder Coated Valve Cover (will also include the upper timing and spark plug covers which have been spray painted to match the VC) - $55 - Sold
Golan -6 fuel filter and -6AN nylon braided fuel feed, stock 1G fuel rail with AN fitting attached for feedline, and fittings that allow the Golan to attach to the stock lines (see pics) - $100 - Sold
Homemade Mini Battery setup - $100 - Sold
CF Hood (w/ CarbonTrix Vent) - $400 - Sold
Brand new Napa Front Pass Axle, still in the box - $35 - Sold
JMF 1G front bumper replacement thingy - $130 - Sold
Brand New OEM Mitsu Plug Wires - $40 - Sold
Tubular front crossmember - $150 - Sold
JMF Race SMIM - $360 - Sold
PTE 1600's - $190 - Sold
Two Walbro 255hp pumps - $120 for the whole setup - Sold
ARP L19's (used for 1 year) - $150 - Sold
ACT2900 PP - The clutch disc was pretty much spent, so just selling the PP. It's used, but could be roughened up and reused - $25 - Sold
Dynatek Arc-2 ignition box - Plug n Play harness for a 1G (not sure if it's the same between 1G and 2G) - $300 - Sold
4" CAI - This was custom made by MAP (= expensive), places the MAS in the fender well, fits perfectly with my S362 but may require slight tweaking to line up with your turbo setup. I tried to show how it also has a bracket right before it bends down into the fender well, that bolts to the body which holds it nice and steady - $100 - Sold
External Oil Cooler and lines (pushlock) - $120 - Sold
CAS - $15 - Sold
Interior Seat Swap - $60
EPROM ECU w/ Keydiver chip - $230
Rolling Shell - SOLD locally!
w/
- Rear Subframe with Jay Racing Toe Eliminator installed.
- 1GNT Throttle Body
- 4-Bolt Rear End
- Adjustable rear upper control arms
- Shifter Bushings
- Tinted Tails
- Evo8 MAS w/ pigtail and 4" adapter coupler, and KN Filter 3 yrs old w/ MAS adapter flange
($1000 rcvd)
DSM 3rd Gen design lifters - appx 5k miles on them - $50 shipped - Sold
Cobra front brake kit. This will include calipers, brackets, bolts and washers, black braided 2G lines, and rotors (rotors have some surface rust where the pads don't contact) - $475 shipped - Sold
Apexi Turbo Timer w/ harness for 1G - http://www.maperformance.com/apexi-turbo-timer.html - $55 shipped - Sold
Stock Coolant Pipe with turbo feel line welded shut by MAP (good for people running oil cooled turbo setups) and used Knock Sensor - $35 shipped - Sold
Evo Shift Knob - $22 shipped - Sold
2G Head & 90 Oil Filter Housing. - $381 shipped - Sold
Mishimoto Alum Radiator - $150 shipped - Sold
Stock oil pan modified with a -AN fitting welded (by MAP) for the oil return & JMF dual chamber catchcan setup - $93 shipped - Sold
2 new OEM driveshaft carrier bearings from the dealer, - $125 shipped - Sold
TRE Stage 1.5 tranny w/ 4-spider center diff, - $600 shipped - Sold
DSMLink V2 with USB cable (no computer included)- $190 - Sold
A/C compressor (has fitting on it for Freeze 12 conversion) - $40 - Sold
Alternator in good working condition - $20 - Sold
ID:	10461   Click image for larger version
ID:	10610   Click image for larger version
ID:	10607   Click image for larger version
ID:	10608   Click image for larger version
ID:	10466   Click image for larger version
ID:	10467   Click image for larger version
