Old 08-20-2010   #1
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
1990 Plymouth Laser RST-This time for Real!!!
Well. I really wanted to keep this project going, but found out today for sure that i have another lil one on the way. And after trying to fit 2 car seats in the laser, i need to up size. Here is some info on the car.
1990 Plymouth Laser RST-Clean title!!
4G63T- 170,000 on short block, Head was said to have 50,000 miles when i put it on. When putting the head on i installed new timing belt, timing belt idlers, water pump, and all gaskets associated with a head swap.
Turbo was replaced with one that was said to have low miles, does not smoke, had little shaft play, can check again if anyone wants me too.
5 speed manual trans-possible 1-2 syncro going out. Grinds when trying to shift fast between gears.Could be the clutch too. Not sure when it was changed last.
New front axles, Newer tires.
Mods:
AEM wideband O2 gauge
Autometer 30-0-30 Boost gauge
Emissions removal, EGR removal with blockoff plate from MAP-Still have everything if you want it.
MAP shifter bushings
Megan Racing downpipe, custom side exit exhaust
Forge MBC
Bad things:
Some of the valve cover bolts are stripped
Has an oil leak, not major, i am thinking its the oil return for the turbo. Gonna replace gasket and see if that fixes it.
Bent that runs the rear quarter. Not to major, previous owner hit a deer.
Dash corner is lifting, Headliner needs to be recovered. Will try to have done before sale.
-I will be fixing as much of the little things as i can before anyone buys the car.
I may be missing some small things about the car, I have a terrible memory. lol. Any questions feel free to ask.
I would love to get around $2000 for the car. But of course price is OBO. I would love to trade for a galant gsx or a vr4 that needs some work. May take other trades, just let me know what ya got.
Thanks for looking.
DSM....Because broken timing belts, cheap interior, transfer case leakage, and crankwalk is to weed out the weak.
