Old 09-16-2010   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Eagle Talon TSI AWD Turbo
Simple run down of the vehicle its a 91 AWD Talon as listed above. It is a turn key start car. The car hasn't given me any serious mechanical problems. Except for a Oil Pump and Transfer case that have been replaced. Oil changes done every 2500 miles. All the fluids have been exchanged within the last 5000 miles. The car has approx 154K miles on it. Its in good shape compared to other vehicles in the market. Ill be up front with everything, i do not want to waste your time so please dont waste mine. It does have a small rust spot which im in the process of fixing with a proper sand down and touch up paint. Its that small. It currently is my daily driver. Your welcome to test drive the car, check it out letting the car do the talking. Compression numbers were a little on the low side. Im open to offers and trades just let me know what you have in mind. Im best contacted by PM or cell phone 612 618 7252 feel free to make offers.
1991 Eagle Talon 1G
Modifications:
Engine:
Stock 6 Bolt Block (Ceramic Paint Coated)
ARP Head studs
Balance Shafts Eliminated
New PCV valve
New Oem Oil pump
Exhaust:
Ported 2G 02 Housing (Ceramic Paint Coated)
2.5" Custom Straight Turbo back Exhaust w/Magnaflow Muffler
*If buyer is interested i have a Tubular manifold as well Mitsu Flanged
Intake:
3" Short Ram Intake Pipe (Ceramic Paint Coated)
Ported MHI Evo 3 16G Turbocharger
3G 501 MAS
Throttle Body FIAV Blockoff Plates
Stock Non Crushed BOV
Fuel:
560CC EVO VIII Injectors ( Brand new Mitsu Dealer O Rings & Lower Injector seals)
Walbro 190 LPH Fuel Pump*
Electronics:
Eprom ECU w/Keydiver Chip
TurboSmart Boost Tee MBC
Drivetrain:
ACT 2600 Clutch Kit
Roller Skate Shifter Bearings
non-cruise throttle cable
Suspension & Brakes:
Option Import Front Strut Bar
Stainless Steel Rear Brake Lines
New OEM Mac Pherson Struts
Adaptive One Front Brake Pads* (Need Replacing)
NAPA Safety Stop Rear Brake Pads*
Blank NAPA rotors (Need Replacing)
New Tie Rods Both Sides
New Wheel Bearings both sides
New Front Passenger Caliper Needed
Interior:
2G DSM Leather Shift Knob
Exterior:
17 Inch OZ Race Wheels
Tire size 215/45R17
Miscellaneous:
FIAV Eliminated
Emissions Eliminated
A/C Eliminated
Cruise Control Eliminated
For the bad
-Headliner missing
-Right Front Passenger Side Caliper Needs To Be Replaced
-Handbrake Needs Replacing
-Needs New Front Brake Rotors soon
-Passenger seat belt dosnt automatically retract by its self locked in the secure position. (Most likely is a fuse i still need to look into the problem)
-Compression Between 130-120 across the board. (Not necessarily bad) Still pulls nicely
-A Pillar trim missing both sides.
Asking Prize 3500 OBO 3500 might seem steep but its a starting point. We all go into this game not expecting to make the money we put into the car back. I just need enough for a GVR4 i have been looking at. So feel free to make offers here and there. Contact info is 612 618 7252
Old 09-16-2010   #2
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Eagle Talon TSI AWD Turbo
Front mount intercooler is in the process of completion j pipe is the last thing left and appropriate couplers. Explanation where there is a FMIC with no piping. Ill get better pictures of the undesirable traits such as the rust spot. scratches and small dent.
Old 02-09-2011   #3
p0larb3ar
Drives: 2005 Chrysler 300
I like it. do you have any pics of the interior?
p0larb3ar is offline   Reply With Quote
Old 03-01-2011   #4
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
I actually do, pm me a cell number or something and ill send them to A your phone or B email C post them on here when i get time.
Old 03-01-2011   #5
Owned
Drives: 2g
3500? low compression? little beat up? kinda high asking price. When you come down significantly let me know
Owned is offline   Reply With Quote
Old 03-01-2011   #6
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
^ ''Im open to offers and trades just let me know what you have in mind.''
If your looking for something like 1800 keep looking. If you have reasonable offers trades ect PM me. As you probably can tell, im not in a hurry to sell AT ALL!
Old 03-07-2011   #7
dsm2die4
Prisoner of Boost
dsm2die4's Avatar
Drives: A better POS than you
If you finish the front mount and clean it up a little I'll come take a look at it, still not for nearly 3500 but I have cash
Suck it up and roll
dsm2die4 is offline   Reply With Quote
Old 03-20-2011   #8
Tauni
Mazda-ing
Tauni's Avatar
Drives: 2013 Mazdaspeed3
I am having a hard time telling from the pictures...is it black or purple-ish?
Old 03-25-2011   #9
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Sorry, its purple-ish? Its the purple silver 2 Tone. This thread probably should be closed. I started gutting it out and just slowly restoring it to its previous condition. I will be removing the rear seat belt assembly's and either sheet metaling for a cleaner look or carpet it.
Old 04-30-2011   #10
TjXiong
TjXiong's Avatar
this car is shitty, not worth the price nor buying it. seen it in person. engine bay sucks including the interiors. all gone and trashy. guages doesnt work properly turbo doesnt seem working right also. good luck for those whos getting the car.
Old 04-30-2011   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
This should explain things.
No need to hate cause you couldn't afford his turbo!
Old 04-30-2011   #12
backwoods
Drives: talon tsi
Hey are you parting it out?!
backwoods is offline   Reply With Quote
