Old 09-20-2010   #1
Jungy
Jungy's Avatar
Misfires at cruise, short video and a log attached
I'm still getting really bad misfires and hesitation under 3k rpm and need help figuring out what the problem is because I've done 3 weeks of trouble shooting so far. This is what I've done so far to no avail:
replaced plugs
replaced wires
swapped out coils
swapped out ign transistors
ran the car in both SD and w/ a 2g maf
added grounds from the neg batt terminal to the sensor grounds and block
Swapped out CAS'
ensured base timing was correct and also that the CAS wasn't 180 out
checked 6 bolt swap wiring
checked all injectors at idle
http://www.youtube.com/watch?v=Icp39MZ5RO4
