Old 09-30-2010   #1
jrohner
jrohner's Avatar
FS: DSM SS Header; Evo 8 turbo; other 1G & 2G parts!
I've got an ebay tubular SS header, used for a few hundred miles (discolored, not cracked). $70.
Evo 8 turbo (no o2 housing or WGA). $120.
I also have a 2G intake manifold, the large vacuum port on top for emissions garbage is removed/plugged -- $30.
2G thermostat housing w/ thermostat, $20; 2G water pipe and lower radiator hose, $20.
2 used water pumps (1-91, 1-99), $10 ea.
2 T25 turbos, shot, one has compressor outlet elbow cut off, with WGA's, no o2 housings -- make offer.
1G intake manifold, $30.
1G fuel rail, $20.
1G non-turbo throttle body w/ TPS (untested), $30.
90 CAS (untested), $30.
1G auto turbo manifold, $10.
2" blue silicone coupler with t-bolt clamps, $10 ea (I have 2).
I can probably bring them with to the dyno day if you're interested in them, since I live 100 miles from the cities.
You're welcome to make an offer on any of my items.
Thanks
Jeff
