Old 10-01-2010   #1
mnnice
shit'll buff out
Drives: 97 talon awd. black
evap canister
hey im wondering about all my emissions stuff. i know i can delete them. and i have a vacuum line diagram. but when it comes to the evap what do i have to cap? and does anyone have anyone have pictures of them doing this? is it worth deleteing all the vacum lines?
thanks for any help!
-Mark
shit will buff out
mnnice is offline   Reply With Quote
Old 10-01-2010   #2
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: evap canister
I pulled the canister and valve out of my old Talon, capped off the vapor line and all the vacuum lines leading to it (left the solenoid in place), never got a CEL.
Originally Posted by Trogdor
Old 10-01-2010   #3
Re: evap canister
VFAQ.COM is your friend
Old 10-01-2010   #4
mnnice
shit'll buff out
Re: evap canister
i didnt even know about that site. haha thank you. anyone looking to help is still welcome to!
shit will buff out
Old 10-02-2010   #5
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
Re: evap canister
Remove everything EGR related, lines and solenoids, put a block off plate over the EGR port and let er' buck. You'll have to cap the lines by the gas tank and on the intake manifold and put a breather filter in place of the PCV valve. Follow the vac diagram
if you want the check engine light to go away you'll have to get a scanner to disable the EGR system so the computer ecu doesn't even look for it on start-up
I believe your engine will run cooler with EGR deleted and what not and you'll need 1 degree cooler plugs too, but this is if you delete the entire system.
But yea, vfaq.com fuckin' rocks. Check it out.
Old 10-02-2010   #6
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Re: evap canister
Take a hose an run it from the gas tank evap line that went to the evap canister to underneath of your car around the stearing rack on the passenger side by the back steering rack bolt. Thats what I did, don't cap it off or let it leak into the engine bay.
I know you have a 2g but I'm not sure you need to get rid of the PCV valve, I didn't on my 1g.
