Old 05-03-2004   #1
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Doesn't seem too bad but I am looking for opinions? :stick:
I need an I/C bad
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
Old 05-03-2004   #2
Looks decent. Does give you the end tanks to do short route piping. It's not as thick as some of the others I have seen but otherwise it's a nice sixed front mount.
Old 05-03-2004   #3
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Looks like heatsoak waiting to happen, but I bet it's pretty efficient. For a drag car only application it may be pretty damn good.
Old 05-03-2004   #4
I got mine off ebay. It looks great works fine and was an extruded tube/fin design. I didnt get mine from that guy though, but was looking at his.
Old 05-03-2004   #5
Also you can get Cores with and without end tanks a bit cheaper as well. Depends on what you want to do with piping and whatnot as well.
Old 05-03-2004   #6
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
It will be going on a drag only car FWD. I am looking to run high10s to low11s on a serious budget.
I just can't see spending $1200-$1500 on an I/C
Thanks for the input guys.
Old 05-03-2004   #7
Jacek
Captain J-Sack
why would you say that?
Old 05-03-2004   #8
illz
"950hp t88 chevy v8 300zx"
well, at least you know the seller is insane.
Old 05-03-2004   #9
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Probably not actually THAT bad. When I first looked at it I thought it was a tube and fin design. I read it and I guess its a bar and plate. Its thin though, and most of it is covered up by the bumper. Its also only about the same CI as the Buschur street core, which I have and tend to heatsoak pretty quickly at relatively low boost on the 50 trim.
On a race car you could deffinately get away with that IC.
Old 05-03-2004   #10
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
My bumper cover is already cut out for a large "Race-Core" FMIC.
Hopefully the welds on the endtanks aren't too shitty.
Old 05-03-2004   #11
Wierd. It says bar-and-plate in the description, but he also said it has rounded tubes, which are usually tube-and-fin or extruded tube. It sure doesn't look like a bar-and-plate from the pics. The core is a bit thin at only 2 7/8, but the 10.5" helps to somewhat make up for it. I really can't see that little core being used on a 900hp car. It isn't going to have a lot of flow area with those thin little tubes and at 2 7/8 x 10.5 it has overall flow area than a 3.5" x 8" Buschur street core. It would probably be rated for about 500hp, but you can often push things like that past it's rated numbers.
Anyways, the price is right and it should work for what you want. You can probably get the piping for it from SLS. SLS has a whole street core kit that you might want to check out also.
Old 05-03-2004   #12
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Cool, thanks for the input guys
Old 05-03-2004   #13
Jacek
Captain J-Sack
nothing beats my 4.25" thick front mount :bounce:
Old 05-03-2004   #14
Raptor
ConArtist
Raptor's Avatar
Not a bad price, but I don't think I would spend the cash without knowing for sure about the core and maybe ask them who made it if they will say. Like Allan mentioned, we can get cores that would put you comparable in price with end tanks made exactly like you want. SLS probably can hook you up pretty well also. At least in either of those cases, you could say how thick you wanted it to be and be more specific on the size.
Either way, I would email the seller and find out for sure what it is.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
