Old 11-01-2010   #1
Garage heating options - 2.5 car
I'm wondering if anyone had any good ideas, I have one of them bullet heaters right now but its on its last legs and I need something better.
I live in a townhome with an association, and I'm hoping to be out of here in 3-5 years.
I keep seeing ideas of a wood burning stove, but I don't really have the room for one.
A friend suggested this http://www.fleetfarm.com/catalog/pro...-garage-heater
Thanks
Aaron
Old 11-01-2010   #2
Re: Garage heating options - 2.5 car
So does that just hang up on the wall then or something?
I personally just use a small Propane torpedo style heater. It's kind of small for my 2 stall garage, but I just wear a hoodie. I feel like it's around 25000 BTU.
I had a much bigger Kerosene one that worked amazing, but I would start coughing really bad, I'm assuming from the fumes it put out. So might want to stay away from those.
Old 11-01-2010   #3
I just found out its a wall mounted heater, which means it won't work for me.
I don't really want another torpedo heater, but it looks like what I'll be getting.
Old 11-01-2010   #4
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Small house furnace works great that's what I have in my garage,but my garage is literally bigger then my house. I just have it plumbed into the gas line for the house. I can it to about 70 in about 15-20 mins. Or you could always get a heater that hangs from the ceilings like most professional shops have. I have seen smaller versions of what they have. I'm on my phone now, but when I get home I will post a link.
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 11-01-2010   #5
I wouldnt use any of the propane type heaters, they put out too much crap in the air unless you have a good source of fresh airflow.
My parents have one of these in their 3 car garage and in a half hour it heats up the garage nicely. http://www.northerntool.com/shop/tools/product_595_595
Id get one of these and then just section off one of the stalls with plastic and work in there.
Old 11-01-2010   #6
^That looks pretty good. I like that, but I'd need a natural gas feed right?
Old 11-01-2010   #7
No its electric! hehe But this one is a 240V model, so you do need a hookup for that..
Old 11-01-2010   #8
lol, i saw after i posted. I do have a 220 outlet and an extra circuit breaker wired outhere, I'll talk to my electrician before I purchase.
This looks like it will be the one, if not I'll get another torpedo style heater
Old 11-01-2010   #9
If you've already got 220V out there, I'd go that way. I put in a big ass natural gas commercial heater in mine and it'll heat my 3-car in under 20 minutes, but running the gas line and exhaust was a pain in the ass. Just don't go with the cheapest, you end up spending more in the long run, it's better to oversize than undersize.
Old 11-01-2010   #10
I talked to my electrician friend and he said that it would cost a lot to run that electric heater.
If it wasn't a townhome that I hope to get out of I would have no problem sticking a big badass heater in, but since I know I want out of it I don't want anything too crazy.
Old 11-01-2010   #11
Well you dont leave it on while you arent in there.. for a few hours every weekend its not going to cost too much.
Old 11-01-2010   #12
mlomker
*Resting In Peace*
mlomker's Avatar
I got bored and researched various heaters this afternoon. Electric sounded like the way to go to me. Even people that run them continuously on low to keep the garage above freezing say that the cost isn't bad.
Old 11-01-2010   #13
I have a 30000btu gas heater in my garage, I wish I had sprung for the 75000btu heater. You can buy a 75k heater at Norther for under $500.
Old 11-01-2010   #14
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Thanks
Aaron
The one from fleet will work. I can show you.
Old 11-01-2010   #15
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
A propane heater like the fleet farm one, or even one of those sunflower heaters that go right on the tank should be just fine. I used a single burner unit and put a fan behind it to heat my 1 car garage to great avail, and despite what these nay-sayers are saying, you arent going to die from fumes. If the flame is blue it isn't releasing noxious gasses and you are safe. Plus your garage will leak enough air into it naturally to not kill you, unless your garage is hermetically sealed.
Old 11-01-2010   #16
curt_gendron
curt_gendron's Avatar
Also consider beefing up your insulation, if you can. That can go a long ways into keeping your garage warm. If you have an uninsulated garage door, they make insulation panels for them. If you can add insulation above the ceiling, that would help a great deal.
later,
Curt
Minnesota 3/S
Old 11-01-2010   #17
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
My friend is researching these options currently, and he did the calculations and running a heater on natural gas is a ton cheaper... to the effect of 30-50%.
Style's automotive engineer
Old 11-01-2010   #18
Yeah, it's a lot cheaper, but the upfront costs of installation and such are higher.
Old 11-01-2010   #19
s1ngletracker
Drives: A BMW
True. So perhaps an electric unit that you could just unplug and take with you when you move would work out. Also depends on how much installation costs..
Old 11-01-2010   #20
T is for TURBO
Drives: A car
Not being a dick, but wear lots of layers and use gloves and use carpet for your back (don't want to mess up your back) ... I know my DSM is gonna break down in the winter "it always does* lol
T is for TURBO is offline   Reply With Quote
