Old 05-04-2004   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Okay so I was driving home and decided to have some fun with some bikes on 494. Long story short I was running about 18 psi and then noticed it tapered off and from then I couldn't build any boost at all. I did notice that there was a decent amount of white smoke coming out from under the car(not the exhaust). Limping it home I noticed that vacuum is normal and operation is normal, but I am not building any boost. I then inspected all the IC piping and it all seems to be intact, I don't have a boost leak tester to figure out if it is a leak. The couplers I could see were on right. I don't really know what else to check. My boost gauge goes from vacuum to 0, but no higher. Is it possible that it is a really big leak? Head gasket?
Applicable mods are:
PTE FMIC
QPR made 2 1/2" piping
GM 3" MAS in blowthrough
Thanks in advance!
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 05-04-2004   #2
Where did the white smoke come from? Did your turbo go? What kind of turbo do you have?
Old 05-04-2004   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
The smoke came from under the car as I was moving, not just from the tailpipe but from under the entire rear end. I do have an exhaust leak so it may have come from there and then spread.
It is a brand new EVOIII 16G with less than 200 miles on it.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 05-04-2004   #4
Are you able to log anything? Are you knocking at all and does the engine sound ok? I know when my timing skipped it wouldnt build boost at all and would knock like mad.
Im not sure but white smoke is usually water/coolant so Im not sure what that could be... I would find out where the smoke came from.. check coolant levels and see if tank is empty otherwise run over things like compression and basics.
Old 05-04-2004   #5
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Alright. I have my logger in my car I can fire it up tomorrow to see. I didn't feel anything out of the normal when it happened so I don't know what is up. After I got home I checked the overflow tank and it was fine, I didn't want to pull the radiator cap right away for obvious reasons.
Yay looks like I get to start driving the minivan again... :razz2:
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 05-04-2004   #6
Jacek
Captain J-Sack
did you hear any sounds, my guess is if you cant build boost at all and blowing smoke then your turbo is shot. check turbo shaft play and freedom of movement.
what did the smoke smell like?
Old 05-04-2004   #7
Did you get the turbo from a reputable shop?
Old 05-04-2004   #8
Raptor
ConArtist
Raptor's Avatar
I doubt the turbo is the issue. The turbo is a brand new Evo. If it is white smoke, it is coolant but where it is coming from is the obvious question. To see if the turbo is the culprit, block the water lines to it and see if the smoke stops. If you want, bring it by tomorrow and we can check it out.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-04-2004   #9
It sounds like a turbo to me. Did a line get pinched or anything? Are you sure there was adequate oil to it? Is it running like crap? If it is an IC leak it will run super rich and run like ass because of all the metered air leaking out. If it still runs ok, but just won't build boost, then it is more than likely the turbo.
Old 05-04-2004   #10
I agree with it sounding like a turbo or a huge ic leak.
But in his case, the car wouldn't run like ass, hince one of the advantages/disadvantages of the maf-t..the 'unmetered' air is about 2 feet of ic piping.
Bring it by matt, we'll take a look at it.
Old 05-05-2004   #11
Yeah, the turbo was a brand new EVO III 16G. Definatly need to make sure those lines are good for both oil and coolant. I know when you installed it you came buy for the lines and bolts and crushwashers so I doubt it's missing any hardware that would cause it.
Old 05-07-2004   #12
Raptor
ConArtist
Raptor's Avatar
Pin came out of the WG actuator. At least that coveres the boost issue. Good reason not to always assume the worse and jump to conclusions. There are too many possible variables to instantly assume a brand new turbo has been blown without actually looking at it.
651-488-7774
