Old 11-24-2010   #1
Troy Rossberg
Troy Rossberg's Avatar
Drives: 98 Eclipse GS-T & a 98 Pontaic Grand Prix GTP Daily Driver
Rims 215/50/17 on 98 eclipse GST?
Does anybody know if 215/50/17 Rims would fit on a 98 Eclipse GST?
Thanks so much if anybody can help me because I would like to know asap
Troy Rossberg is offline   Reply With Quote
Old 11-24-2010   #2
Re: Rims 215/50/17 on 98 eclipse GST?
It should work, but thats a little on the tall side. Might be a good thing for you being fwd an all.
Old 11-24-2010   #3
Troy Rossberg
Ok sweet, I think Im going to just run them on the street because when I race I plan to put some bigger tires on the back end and smaller on the front end. Since Im going to try and run street tires at the drag track for the Wednesday night street drags in brainerd and with the new engine build that Im planning on doing, I should be putting about 400hp to the crank. So Im gonna see how well I can run on street tires.
Old 11-24-2010   #4
That doesn't make any sense to me at all.
If u are just talking tires, then you would want a taller tire up front. Most run a smaller up front to fit a taller slick.
It sounds like u are just running normal tires if so I'd run taller fronts then rear.
Old 11-24-2010   #5
Troy Rossberg
See I have heard that running bigger tires in the back pushes all the weight of the car to the front, which makes the car have better traction because the weight is on the front tires.
Im not sure what route would be better because I always hear mixed thoughts lol
Old 11-24-2010   #6
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
I run 225/50/16s on my TSI 2g
215/55/16s where my old ones
As far as my research goes your good on both those size tires up to 18''s
Red 1995 Eagle Talon TSI-Original California car-
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
-151k -waiting on 7 bolt to blow-
Boostn2g is offline   Reply With Quote
Old 11-24-2010   #7
jrohner
jrohner's Avatar
215/50-17 is the stock size on 97-99 GSX's. I run 245/45-17, a little taller and a lot wider.
Old 11-25-2010   #8
jrohner
jrohner's Avatar
For FWD you'd want the taller ones in the back if anything, to keep weight on the front end. Like for suspension how you would lower the front, or raise/stiffen the rear.
Old 11-25-2010   #9
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
wouldnt it matter if your fwd or awd though there will be no pushing anything to the front if your fwd your pulling . . . no matter what . . unless your driving in reverse.
Old 11-25-2010   #10
I was thinking that when I was typing, I got confused. Sorry Troy. :flowers: me =
Old 11-25-2010   #11
Troy Rossberg
Its ok where always hear to learn new things lol
