Old 01-06-2011   #1
srxboy
Drives: 1995 gsx, 2007 r1
2g awd part out
After selling my car and getting completly screwed over its getting parted out. It has around 10,000 miles on everything and made 408whp at rs running 20psi. As of now I am only parting out the motor and related parts:
-2.4 6 bolt with eagle/wiesco bored .020 over, block was decked, balance shaft deleted, new oil and water pump, arps studs, 6 bolt head ported and polished stang 3 or 4, 3 angle valve job, bc springs and bc 280 cams $2200
-TRE awd manual trans, evo 3 input shaft, evo 3 1st and 2nd gear, double syncro 2nd, 4 spider center diff with torenton bearing upgrade, lsd front diff, everything was shot peened, all new bearing and syncros $2000
-aem wideband $125
-sbr front mount incooler $500
-act2900 with new sprung 6 puck $200
-hks bov $100
-fidanza 6 bolt flywheel $100
-smim was told it was an early magnus but idk $100
-oil cooler setup, b&m cooler with an lines from oil filter housing $300
-3" hahn racecraft exhaust setup for 3" vband $200
Im sure I will be adding to the list as I go. Prices are obo
Call or text 952-292-7224
srxboy is offline   Reply With Quote
Old 01-06-2011   #2
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: 2g awd part out
Can you send me a pic of which wideband it is? Does it have the digital readout in the middle plus the sweepings lights around the outside?
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 01-06-2011   #3
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
Re: 2g awd part out
are you parting out the chassis?
Red 1995 Eagle Talon TSI-Original California car-
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
-151k -waiting on 7 bolt to blow-
Boostn2g is offline   Reply With Quote
Old 01-06-2011   #4
OMFGeofffff
OMFGeofffff's Avatar
Drives: '90 Talon Tsi AWD
Re: 2g awd part out
Pm'd
OMFGeofffff is offline   Reply With Quote
Old 01-07-2011   #5
srxboy
Re: 2g awd part out
Not parting out the chassis yet.
GG_9_SE it has the sweeping lights around it to
Old 01-08-2011   #6
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
Re: 2g awd part out
let me know if you part out the chassis
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
