Old 01-08-2011   #1
140mph part out- quality parts
Tial 44 wastegate. Its the old taller version with a .9 bar spring in it. It's polished and in great working condition! - $175
Evo8 valve springs (2 sets, only one set has retainers) - good upgrade from the DSM ones I've read: $25
15" Kirkey Aluminum Pro Drag Seat with Black Tweed Cover - $180 local pick up only unless buyer pays for shipping
SBR Intercooler - $250 - I paid 900+ shipping on this thing. Just want it gone
2g side mirrors - $5
2g shifter base - $5
2ga side skirt end caps - $5
2g gray air bag (driver side)- $5
2g side markers: not perfect and appear to be sanded down - $1
2g duct for stock smic - Free - local pickup only
2g seat belt crap - Free - local pick up only
2g brake pads - Not sure on brand but look pretty new - $5
Stock looking evo air box filter - $5
2g trunk stuff - best offer - local pick up only
2g radiator: comes with one fan and is trimmed on the side. Not fancy but works perfect: $10
Russell -4an line - $20
Crank pulley: has separated but could use as a spare? - free
2g battery bracket (what the battery sits on) - $Free
2g gas cap - $5
2g passenger window motor assembly - Free - local pick up only
2g starter plate - manual - $5
2ga passenger headlight - Free
2ga reverse lights: dad tried to night shade them and it the paint cracked. Started sanding them but gave up - $Free
2ga Driver side door molding - $Free
2g evap crap - free - local pick up only
2g water pump pulleys (have 2 of the big pulleys and 1 of the smaller one) - best offer
2g dead pedal - free
2g gas pedal stop - free
2g clutch reservoir top - $5
2g coolant housing - $5 bracket is modified/cut so it bolted in where the stock intercooler piping was. Comes with sensor
2g timing tin with sensor - best offer
2g oil filter housing: was in a motor with a spun rod bearing - free if anybody wants it
2g triangle under brace (passenger side) with bolts - $5
2g door duct - free picked up
2g front brake calipers: come with hawk hps brake pads - $65 for both picked up or $40 per side
2g abs computer - free picked up
2g stock amp - free picked up
2g oil return line: a little bend at the end - $Free
NOS pressure gauge with adapter - $20
Smoked evo turn signals - $15
NOS Pressure on Demand system with automatic bottle opener - $400
2g manual front awd passenger and driver side axle - $50 for both, or $30 for each
2g drive shaft - $15
2 sets of stock evo8 cams - $25
7 bolt ARP headstuds - $40
Pictures:
http://s6.photobucket.com/albums/y20...CA/for%20sale/
