Old 02-18-2011   #1
Troy Rossberg
Troy Rossberg's Avatar
Drives: 98 Eclipse GS-T & a 98 Pontaic Grand Prix GTP Daily Driver
Exclamation 95 7 bolt motor in a 98 eclipse, Crank Sensor
Ok Im looking at picking up a 95 7 bolt motor from a local and Im planing on dropping the motor in my 98 eclipse and the guy I bought the motor from said something about the crank sensor is different on the 95 motor compared to the 98 motor.
My question is what's the difference and what do I have to do to get the motor to run in the car?
Thanks Troy.
Troy Rossberg is offline   Reply With Quote
Old 02-18-2011   #2
Re: 95 7 bolt motor in a 98 eclipse, Crank Sensor
It's not the crank sensor, it's the cam sensor. The 95-96 have the sensor behind the cam gear, the rest have it on the other end of the cam right on the passenger side of the valve cover.
You should be able to take the necessary parts off your old 98 motor and put them on the new one.
Old 02-18-2011   #3
Troy Rossberg
Ok so I should be able to use the 95 7 bolt motor and 95 7 bolt head without any fabrication to the wiring?
Old 02-18-2011   #4
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Yep just swap sensors.
Amsoil Dealer
Old 02-18-2011   #5
Troy Rossberg
Will placing a 98 cam in the 95 head allow me to connect the 98 cam sensor?
Old 02-18-2011   #6
95talonracer
Finally Tuned...
Drives: Spyder GSX
Im 95% sure the cam is already cut to fit in the sensor but otherwise yes that is all that would be needed.
Amsoil Dealer
Old 02-18-2011   #7
Troy Rossberg
Ok sounds perfect, Ill be giving you call tomorrow
