Old 04-07-2011   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
FS Tons of DSM Parts
Here are some of the parts I have. Let me know if there is anything you need via PM or text me at 763-286-273o
2g
Intake Manifold
Map sensor
Coil
Power transistor
Throttle body
Intake air control valve IACV
Throttrl position sensor
TPS
Resistor box
Upper boost pipe to TB elbow
Upper radiator hose
Lower radiator hose
Fuel pressure solenoid
Battery tie down strap
Main window switches
Transfer case bolts
exhaust manifold gasket
02 housing gasket
driver side mirror
Passenger side mirror
Plug wires
Exhaust manifold heat shield
Valve cover bolts
Intrepid coil pig tails
Hard upper stock intercooler pipe
Stock BOV
Shifter assembly
Passenger air bag
Driver Air bag
Gauge cluster trim
Lower intercooler pipe
Stock intercooler side mount
Charcoal canister
New starter
Intercooler shroud
Turbo coolant line
Tranny motor mount (bolts onto tranny)
-10 AN oil pan adapter
Shift fork boot
Front tranny/motor mount
Driver motor mount
Stock fuel pump
AWD fuel sending unit
Cup holder
Harmonic balancer
Horn
Rear main seal housing
Timing pulleys
Fuel supply line
Radio/HVAC trim
Stock exhaust manifold
Intake pipe
Stock air box
Power steering pump
AWD driver axle and half shaft
AWD passenger axle
talon taillights
Soft AC lines
Fues box
E brake cables AWD
Gray center console
Center console plastic sides gray
95-96 t case manual
97-99 t case manual
Gray door panels
Rear gray leather seats
Fuel rail and regulator
Thermostat housing
Talon 95 front black bumper
Talon 95 rear black and a red bumper
Black hood
Stock downpipe
Steering wheel
1g
J pipe for 14b/16g
Fuel rail and regulator FPR
Driver side mirror black
90' 4 spider differential center diff
Smoked 1ga side markers
Gauge cluster
Radio trim
Thermostat housing
Non turbo throttle body
Green CAS
Black top CAS
Power transistor
14b WG actuator
Oil filter housing -10 adapter fitting
Plug wire cover
Intercooler
Steering wheel w/o horn black
Driver flip up headlight
Lower timing gear
6 bolt tensioner timing bracket
power steering pump
Talon smoked taillights
1gb headlights
Passenger eclipse taillight
Center console carpet
A pillars
T case 22 spline and 23 spline manual
1gb talon white side skirts
1gb rear white bumper
Evo
Upper hard intercooler pipe w/ 50mm v band bov flange
lower hard intercooler pipe
Other parts
Ford GT Supercar fuel pump like walbro 255 in size but is equivalent to walbro 330
Amsoil Dealer
Old 04-07-2011   #2
Re: FS Tons of DSM Parts
Hey I'm gonna try and grab that TB from you this weekend.
Old 04-07-2011   #3
95talonracer
Finally Tuned...
Drives: Spyder GSX
Ok cool sounds good.
Amsoil Dealer
Old 04-07-2011   #4
IWantA4g63t
IWantA4g63t's Avatar
Drives: 1992 eagle talon tsi. auto.
How much for the 1gb rear white bumper?
1992 Eagle Talon Tsi. Auto. FP 18g, Ported 2g mani, 5 spd eprom/V3 lite, Evo3 cams ,950cc injectors, AFPR, 3in intake with 2g mas, Perrin filter, 255 fuel pump, 2.5 turboback exhaust, FMIC, Greddy type s, ARP L19, E85.
1994 Honda Civic DX
IWantA4g63t is offline   Reply With Quote
Old 04-07-2011   #5
95talonracer
Finally Tuned...
Drives: Spyder GSX
PM sent
Amsoil Dealer
Old 05-14-2011   #6
rabeb25
Interesting in the radio trim, and what condition the wheel is in.
Thanks
Bryan
rabeb25 is offline   Reply With Quote
