Old 04-10-2011   #1
Chim55117
Drives: 2007 BMW 335i Coupe
1991 Eagle Talon TSi Performance Partout
Stainless Steel VRSpeed Factory J-pipe - $40
http://i749.photobucket.com/albums/x...aphy/005-1.jpg
EXHAUST
2G O2 housing, professionally port matched to an EVO 3 16G hotside. -$40
http://i749.photobucket.com/albums/x...Partout039.jpg
EVO 3 exhaust manifold, no cracks, hole tapped for EGT. - $60
http://i749.photobucket.com/albums/x...hy/photo-3.jpg
http://i749.photobucket.com/albums/x...y/photo1-2.jpg
EVO 3 16G, needs a rebuild. - $160
http://i749.photobucket.com/albums/x...aphy/002-1.jpg
http://i749.photobucket.com/albums/x...aphy/003-1.jpg
http://i749.photobucket.com/albums/x...aphy/004-1.jpg
COOLING
Setrab oil cooler with AN lines and fittings for 1G 90 housing will bolt right on to a 1G. - $150
http://i749.photobucket.com/albums/x...graphy/027.jpg
http://i749.photobucket.com/albums/x...graphy/022.jpg
ELECTRONICS
1x 1G EPROM ECU - $130
http://i749.photobucket.com/albums/x...aphy/016-1.jpg
Autometer Narrowband - $10
http://i749.photobucket.com/albums/x...aphy/010-1.jpg
Autometer EGT, no EGT or bung - $5
http://i749.photobucket.com/albums/x...aphy/009-1.jpg
Greddy Profec B (blue/clear housing) - $100
Greddy 60MM EGT - $30
Stewart Warner 0-40PSI boost gauge 60MM - $30
DRIVETRAIN
ACT 2600 w/6 puck disk, 4K miles on the disk, was in great running condition - $100
http://i749.photobucket.com/albums/x...aphy/023-1.jpg
http://i749.photobucket.com/albums/x...aphy/024-1.jpg
1G Driver's side mount with poly mount - $30
http://i749.photobucket.com/albums/x...aphy/019-1.jpg
1G poly tranny mount - $30
KYB AGX Adjustable Struts on Eibach Springs - $200
(two of the lower mounts on the rear struts came out rough, may need to be replaced, other than that they are in good working condition. The coating on the springs is coming off a bit. This is outrageously cheap, haha)
INTERIOR TRIM
1G pillar with gauge 3 gauge pod - $20
http://i749.photobucket.com/albums/x...aphy/018-1.jpg
FUEL
Denso 550CC injectors - $80
Items I'm willing to take as trades are decent 2G AWD suspension, AEM fuel rail, or 2G/EVO ECU flash cable.
Give me a text at 612.381.6195 for details. Include your forum name/actual name. I have a few ads up on other forums so this really helps me out.
Thanks for looking.
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Chim55117 is offline   Reply With Quote
Tags
fuckin prizes y0
